2002 CAT P5000 REALLY DIRTY TRANS FUILD
In my life as a mechanic. I have not seen a dirtier trans fluid. It was black, gritty, and particles of fiction pad. Forklift came in for transmission not going Forward or Back, Intermittently.
I have flush the system with Diesel Fuel about four-times (Filled, cleaned screen filter, run & drive forklift, drain system). After about 4-times, fluid looks about 80% better but there's still particles. I think the fiction pads are deteriorating, but why the black gritty particles don't stop?? The hours on the motor is under 3000-hours and the transmission does not slip. What do you think??
  • Posted 15 Dec 2014 13:31
  • Modified 15 Dec 2014 13:42 by poster
  • By 808FORKLIFT
  • joined 8 Dec'14 - 39 messages
  • Hawaii, United States
I haven't smell anything, but the fluid was Black & Gritty. I really don't know if the owner of the forklift put in the wrong trans fluid.
After flushing the system out 4-time. I replaced the fluid with Amsoil and add trans fluid conditioner. Hope that would stop the deterioration of the plates and improve the rubber seals in the trans. If trouble starts again, guess got to rebuild the trans.
  • Posted 16 Dec 2014 15:40
  • By 808FORKLIFT
The only time I've seen grit/chunks of disc friction material is when a wrong type of trans fluid is used. Usually a trans which has pressure issues which cause the friction plates to wear- the material coming off the plates is extremely small, not gritty & the trans fluid smells burnt- it really stinks. Did yours have a strong odor of burnt fluid?- I suspect not.
  • Posted 16 Dec 2014 07:18
  • By bbforks
I have run & driven the forklift between changes, so the torque convert should be flush as well.
This Screen Filter between the Control Valve (Forward/Rev Solenoid) and Valve Body. I don't see it. I have washed and blew out the Solenoid many time. I don't see any mini screen any where. How can a 3,000-hours trans burn up so quickly and deteriorate?? Very hard to believe??
Does any body know how much a Reman-Transmisssion cost about?
  • Posted 16 Dec 2014 04:42
  • Modified 16 Dec 2014 04:54 by poster
  • By 808FORKLIFT
Sounds like a trans flush is in order at a minimum ( the kind in the automotive world- where the engine is running & the trans cooling lines are connected to a fluid flushing machine).
I must admit that the debris in the oil is a very bad sign- I'd prepare the customer for a trans replacement/rebuild.
  • Posted 16 Dec 2014 04:36
  • By bbforks
Keep in mind that torque converter is full of that dirty oil, that doesn't come out, when you pull the drain plug.
  • Posted 16 Dec 2014 00:17
edward is correct, you cannot go by 'feel' , you have to use pressure tests to know what is going on inside these transmissions.
flushing the transmission case with diesel fuel is not going to get you a good cleaning so you will have debris floating around. It would take several fluid and filter changes after running the lift to get the fluid clean OR pulling the transmission and disassembling it and cleaning it which would be during a rebuild generally.
also there is a screen nobody thinks about that is in the control valve area which is what in training we were instructed to call the 'last chance filter'. It is a small screen in the ports between the control valve and the transmission body, it is not shown in the manual either, it is part of the assembly and if it gets clogged that will throw pressures off and could keep the truck from pulling. Also check the strainer located in a plug under the solenoid valve chamber.
If you want to see the condition of the plates you can pull the control valve and take a physical look at the plates if you like, you can usually get an idea of what condition they are in that way.
I think you'll find if you have that much debris floating around inside the unit these plates will be worn out.
I suggestion would to be start looking for a reman transmission unless your in the mood to rebuild one.
  • Posted 16 Dec 2014 00:11
you say "trans does not slip", ?is that from feel, or from taking pressure tests?
These trans don't really -feel- like they slip until the pressure is lower than about 75 PSI, but it -should- be around 150 to 175 PSI, (someone else can look up the exact numbers for us) and IS slipping the clutches at lower pressures (like riding with the operators foot resting on the inch pedal).
Disassemble the inching linkage bell-crank, and lube the shaft, so that it moves freely.
  • Posted 15 Dec 2014 22:11
  • Modified 15 Dec 2014 22:13 by poster
Terberg YT222
Toyota 8FGCU25
Flesherton, Ontario, Canada
Philadelphia, United States
Prospect CT, United States
Dayton OH/Cincinnati OH, United States
Rob Ott Rob Ott
Executive vice president and chief commercial officer, East Penn Manufacturing
President, Logistics UK
Director of dealer development East Coast, Big Joe Forklifts
Vice president, customer, TVH Americas
ASSET FINANCE
Nov 2025
October 8-10, 2025 - Lucca, Italy
June 17-20, 2026 - Bangkok Thailand, Thailand
August 19-21, 2026 - Bangkok Thailand, Thailand
Funerals in Spain typically occur within 24 to 48 hours of death, whereas in other European countries they wait one or more weeks. This rapid timeframe is a cultural norm grown from the past need to manage the warm climate without modern embalming.
