Premature teeth failure on ring gear and starter SN#63924
Hello all
We have a truck that wears out the teeth on the ring gear and starter fairly quickly. Say course of 8 months. This will be our third time in. After repairs everything sounds normal. Doesn't appear to be going to deep or to shallow on the gear. But obviously something is wrong. Anyone else seen this. Are there updates I'm not aware of??? Signed Cornfused!!!
  • Posted 25 Nov 2014 23:29
  • By ChrisD
  • joined 1 Mar'12 - 21 messages
  • Kentucky, United States
Quick check on the relay,swap it iwith the sister truck relay and see if symtom swaps to other truck??????
  • Posted 27 Nov 2014 09:51
  • By kevin_t
Like the the thought on the starter relay. We ordered and will try.
It has the 4Y motor. both units and use same starter.
Crossing my fingers with relay.
  • Posted 27 Nov 2014 09:24
  • By ChrisD
What engine is in this lift & is the sister lift exactly the same model with the same engine?
  • Posted 27 Nov 2014 08:08
  • By bbforks
One thing i would check is the start relay....is it sticking when key is released from start position,if contacts in relay are sticking then will keep the starter engaged longer after key released....just a thought and WAG....
  • Posted 27 Nov 2014 08:06
  • By kevin_t
It is being started and stopped a lot but we have a sister truck in the area and has no problems. The bendix on the starter is hanging out very briefly after each start. We think this may be the issue.
With regard to parts the first ring and starter both came from TVH. So the second time around we got them from Toyota. but experienced the same result.
What would cause the starter sprocket to hang out very briefly after each start??????
  • Posted 27 Nov 2014 06:41
  • By ChrisD
if the operator shuts off the machine after every pallet taken off a truck, or every time he gets in or out of the operators seat, to would not be odd to start a forklift 56 times a shift, where in your car, your mean daily average is 3 starts a day.
there is good reason that OSHA allows you to -properly- park a forklift and leave it running if you are within 8 meters, are able to see the forklift.
make sure you don't have a key switch that allows restart without going all the way to 'off'.
  • Posted 27 Nov 2014 06:03
A couple of things- where are you getting your parts & what is the normal life of the lift- starting every 5 minutes or running all day- limited starting?
  • Posted 27 Nov 2014 01:25
  • By bbforks
UN Forklift FD15-18T
Mitsubishi FD200
Sue Tomic Sue Tomic
