walkie stacker pallet jack creeps slowly down when lifted
walkie stacker pallet jack creeps slowly down when lifted.
I would guess it is either air in lines or a valve by passing?
Is there a bleeder valve or how would you get air out of lines?
Any help would be appreciated.
I am looking for a pdf manual on line to help me.
  • Posted 30 Aug 2014 05:43
  • By netpreneur
  • joined 26 May'12 - 27 messages
Thank you Kevin I will check that out.
  • Posted 31 Aug 2014 06:45
  • By netpreneur
Couple of possibilities,either the pressure relief valve is stuck partially open or leaking by....or the hydraulic cylinder piston seals are bleeding by and the cylinder needs repacked....
  • Posted 30 Aug 2014 13:04
  • By kevin_t
