caster brakes engage while driving and lock up on driver
I got called out two weeks ago for service call I get there one guy says the caster wheels which have drum brakes lock up other guys say it spin to much. Any way so I take the wheel off notice the adjustment is a little tight.I adjusted it and put back to service. Got called out today one wheels had heavy flat spots.seems like one side engages while driving
  • Posted 29 Aug 2014 10:59
  • By crown619
  • joined 28 Aug'14 - 26 messages
I read the service manual and this system has two master one for the drive unit another for the caster I noticed the rod for the caster master not moving s o I have to go Tuesday and check if their something missing (roll pin on the rod)
  • Posted 30 Aug 2014 14:22
  • By crown619
One other POSSIBILITY is that when the operator lets off the deadman pedal abruptly the drive motor brake is loose on adjustment and the caster wheel brakes lockup faster and drag as the truck is still moving.......
  • Posted 29 Aug 2014 13:46
  • By kevin_t
Its on a hydraulic system im gonna have to read the manual seems like a adjustment or master not holding pressure.doesn't Happen all the time.
  • Posted 29 Aug 2014 12:22
  • By crown619
Can be a air gap problem on the brake assembly also,is something to,check.....
  • Posted 29 Aug 2014 11:27
  • By kevin_t
Are the operator(s) FULLY depressing the deadman pedal???I had one operator at a place I service that only half pushed on the deadman causing the brakes to not release this was on a hydraulic brake system but can happen on a electric system also if switches are out of adjustment....I would watch how they operate it and watch how their feet are on the pedal
  • Posted 29 Aug 2014 11:22
  • By kevin_t
Tusk 500PGH16
Morooka MFD20
Tusk 500PGH16
Morooka MFD20
