Code 353
i have a rr5225 that keeps getting event code 353 have swap out both access 3 and access 2. with no luck. wiring for comunications check good. please help
  • Posted 28 Aug 2014 21:48
  • By josh_j
  • joined 4 Jul'14 - 4 messages
  • Michigan, United States
i replaced distribution board, access2, and swapped out access 3 had truck running for a da after i installed new distribution board. now im getting a code 353 and the access 1 locks out until you key the truck on and off
  • Posted 19 Sep 2014 02:50
  • By josh_j
Check connections at dist board. Clean them with light amount of contact/electrical cleaner and light compressed air. Do you have another truck (same model) you can swap dist boards with to see if the problem follows? Good luck!
  • Posted 29 Aug 2014 04:45
  • By chevotaman
  • joined 28 Feb'14 - 112 messages
It's all just nuts n' bolts.
MAXAM Tire, Inc.
