lifting issues
i had the valve body sent off to be repaired due to the forks drifting when it returned the problem is worse than before now whe i try to tilt it forward it raises to max heigth before tilting forward when i tilt back it will til bottoms out then raises this lift does not have side shift and if you hit side controls it raises all wiring is correct and it is an elctronic valve body thank you
  • Posted 6 Aug 2014 08:00
  • By rosscoe
  • joined 6 Aug'14 - 8 messages
  • Oklahoma, United States
Check out the relays for the controls I have had this issue once before on older mitsubishi esr relay welds it self together and no matter what I would touch control wise the welded contact function would operate
  • Posted 12 Sep 2016 12:44
  • By matthew_l
  • joined 24 Aug'16 - 4 messages
  • New Jersey, United States
hi
Did you manage to calibrate your valve. If so, can you let me know how to do it please..Thanks
  • Posted 25 Mar 2016 02:58
  • By LP35
  • joined 10 Aug'12 - 32 messages
  • Quebec, Canada
serial # is GOO4VO3112E
  • Posted 6 Aug 2014 21:46
  • By rosscoe
Have an email to put in your profile?.
  • Posted 6 Aug 2014 09:34
  • By kevin_t
I will have to get back with you in the morning on that I have already left the shop
  • Posted 6 Aug 2014 09:28
  • By rosscoe
What is the serial number of the truck?
  • Posted 6 Aug 2014 09:17
  • By kevin_t
We also tried it before pulling valve body
  • Posted 6 Aug 2014 09:09
  • By rosscoe
We tried a reman one that we have extra same outcome
  • Posted 6 Aug 2014 09:08
  • By rosscoe
Sounds like the electronic controls need to be calibrated. This may have been the problem in the first place.
  • Posted 6 Aug 2014 08:24
  • By bbforks
Toyota 8FG25
Taylor TT300
USD98,500
Toyota 8FG25
Taylor TT300
USD98,500
