error codes 302, 306, 312, 317
SC4510-30 with the above codes.
Does anyone have a listing?
  • Posted 13 Jun 2014 07:28
  • By mowers
  • joined 29 Jan'10 - 27 messages
  • Alberta, Canada
Good afternoon friend, I have a similar equipment, it occasionally throws me event code 327, there is not much information in the service manual, you will have more information.
thank you so much!
  • Posted 6 Jul 2024 14:11
  • By DavidFuenzalida
  • joined 17 Nov'23 - 2 messages
  • Chile
an affectionate greeting
David Fuenzalida
302: Access 3 Logic Error #2, error in the U,V,W voltage feedback circuit: STEP1: Check line contactor is connected and getting proper voltage, 36v at pull-in then 24v continous. Check tips. STEP 2: Check traction motor cables at motor and Access 3 for shorts and continuity.
306: Voltage present at B+ terminal before powerup. STEP 1: Check line contactor tips. STEP 2: Check power cables are not shorted, if OK replace Access 3.
312: Line contactor driver open. STEP 1 Disconnect CA403 at Access 3 and check resistance between pin 26 and pin 27 on wire harness, should be 70-78ohms. If OK, step 3, if not ok, Step 2. STEP2: Disconnect line contactor coil wires and measure coil resistance, should be 70-78ohms. Out of range, replace coil, if in range, issue lies in wiring from Access 3 to coil on aformentioned pins. STEP 3: Replace Access 3
317: Brake Pedal Error, Brake Switch BRKS1 and brake pot POT2 mismatch. Go to Analyzer menu A2.2.3 and verify brake pot is between 15-20% when BRKS1 changes from zero to one as you slowly depress the pedal. Calibrate in calibration menu or manually adjust as required. There are a lot more fault finding steps for this code but normally its just a mismatch and I can't be bothered typing them all in.
Your major issue is in the first 3 codes, worry about those first...hope someone hasn't plugged a charger into the truck by mistake and fried Access 3!
  • Posted 15 Jun 2014 13:03
  • By techno_nz
  • Canterbury, New Zealand
SMV (Konecranes) 4632CC5
Taylor TXB180S
Taylor TXB180S
