starter leaks!
The starter on this lift leaks oil. Pulled it off and had oil drain out of the starter mount. I realize it is a wet bell housing, but what am I looking for to find the source of the over filling of the bell housing? There is a hose that runs to the top of the hydraulic tank from the top of the bell housing but there is nothing attached to it inside the bell housing.
  • Posted 24 Apr 2014 03:03
  • By lvscr
  • joined 24 Apr'14 - 41 messages
  • Idaho, United States
Showing items 1 - 15 of 15 results.
We have a lift like that. The starter went out on it and I figured out the flywheel rides in oil. Replace your starter and seal it ( the starter) with silicone. Be sure you clean all surfaces. I had to do mine twice. Good luck
  • Posted 27 Aug 2014 09:20
  • By clarkster
  • joined 23 Apr'13 - 11 messages
  • Tennessee, United States
got a GM engine in it?
if so the best i can tell is that this system is fed by a return line from the steering orbital valve going to the bellhousing, the 'scavenger tube' as he put it feeds back to tank. It circulates hydraulic fluid through the bell housing to keep the pump drive chain wet for lubrication.
As for how much fluid is supposed to be in there? Well it would only stand to reason that it will maintain a certain level if the return line is functioning properly, what that level is i do not see any references to this. If they hydraulic pump happens to be leaking into the bellhousing i don't see this as any problem other than it may cause some pressure build up which might be the cause of the starter seals being blown out? causing the leak?
Not really sure how to test for this though unless you have a way to remove a bolt or some other plug gaining a clear access to check internal pressure while the engine is running and hot to see if there is much pressure inside the bellhousing after it runs a while. I'm sure there will be some pressure but how much is the real question.
If the pump is leaking bad enough it could fill the bellhousing up too quickly and the scavenger tube would not be able to keep up with the amount and allow the compartment to fill up too much.
  • Posted 25 Apr 2014 22:18
No it is an automatic.
  • Posted 25 Apr 2014 12:33
  • By lvscr
Is this unit a manual shift trans?
  • Posted 25 Apr 2014 10:16
  • By bbforks
this would not be the first time a hydraulic pump had leaked into the bell housing.
  • Posted 25 Apr 2014 08:38
That is how it appears to be. Without pulling the pump assembly off I do not know for sure.
  • Posted 25 Apr 2014 08:07
  • By lvscr
May this truck have a hydraulic pump that is driven through the bell housing?
  • Posted 25 Apr 2014 05:09
The hose that goes to the top is the scavenging tube hose. It catches the oil slung by the spinning torque converter and returns it to the tank. Not sure about the XL model, but the older machines had a way to unbolt that and adjust it. If you can take that off, check it, but something tells me that on the newer machines you can't access it.
  • Posted 25 Apr 2014 02:47
Not that I have seen. There is something called a scavanging tube that I keep reading about that cracks alot and will cause this issue. But I think the trans has to be pulled to get to it. Also, the hydraulic pump is mounted to the bell housing. It mounts from the engine side of the bell housing. Could there be a seal there that is leaking?
  • Posted 25 Apr 2014 01:01
  • By lvscr
Sounds like the return from the bell housing is clogged- there should be about 2-3" of oil in the bottom of the housing- it shouldn't be full. I'm not familiar with your exact machine- are there any other hoses coming off the bell housing other than the one on the top?
  • Posted 25 Apr 2014 00:34
  • By bbforks
I had the back end of the lift raised about 10 inches off the ground and about a quart or so of oil came out of the mounting hole on the starter when I removed it. I lowered the lift and returned the next day to quite a bit of oil on the ground. Is there a place or way to check the oil level? I heard it was one of the bell housing bolts but do not know which one.
  • Posted 25 Apr 2014 00:18
  • By lvscr
When you removed the starter- where was the level of the oil in the bell housing?
  • Posted 25 Apr 2014 00:09
  • By bbforks
Model S50XL
  • Posted 24 Apr 2014 23:24
  • By lvscr
repair the starter
replace the mount gasket when remounting
job done
nothing else to do
  • Posted 24 Apr 2014 20:24
IT MIGHT BE NORMAL FOR OIL TO BE IN BELL HOUSING STARTER IS BAD.SEAL IS BAD IN STARTER.WHAT TRUCK IS IT
  • Posted 24 Apr 2014 13:03
  • By raj_h
  • joined 24 Apr'14 - 9 messages
Combilift Ltd
