Speed problem
I changed the pot. In either direction if I twist the grip 1/3 a turn it's fine then when I twist more it quits. Does this in both directions. I got into the system and centered the pot by the volts. The book says something about counts? Can't figure out how to adjust that if it can be? The pot was from TVH.
  • Posted 15 Apr 2014 13:24
  • By erik_j
  • joined 11 Dec'12 - 19 messages
In the analyzer menu, centre pot to zero counts, make sure the pot is centred, there can b a deadband at the end of a rotation, the pot is still not centred, turn pot if value changes smoothly, in both directions, then that is middle.
  • Posted 26 Apr 2014 18:21
  • By southernviking
  • joined 25 Mar'13 - 43 messages
  • South Island, New Zealand
Best place for a TVH pot is the nearest bin.
  • Posted 18 Apr 2014 21:03
  • By Forkingabout
  • england, United Kingdom
Have you tried calling your TVH Dealer for assistance?
  • Posted 18 Apr 2014 06:26
  • By AllForkParts
  • joined 18 Apr'14 - 1 message
Also could be the pot itself I have had pots bad out of the box and this is more common in my experience with aftermarket pots and encoders. I always stay OEM with these parts nowadays.
  • Posted 16 Apr 2014 03:08
  • By chevotaman
  • joined 28 Feb'14 - 112 messages
It's all just nuts n' bolts.
Do you have your pot zeroed 180 deg out? Some pots have a stop in them and some do not. The pots that do not have a stop will have two points of zero. If you are set up on the wrong zero the machine will fault out. The counts are how the access controller gets the command from the pot like an encoder. You should be able to see that through your access 1 in service access analyzer. Are you getting a fault code when it fails?
  • Posted 16 Apr 2014 03:00
  • By chevotaman
Enforcer FLBAXT25
Hitachi HX64B2
Lift Technologies Inc.
