No foward/ code 53-23
reverse works, no fw contactor does not pull in. im getting voltage from control card Fw and Rev.
Truck has a EV100 traction card. can any one help me with this problem.
  • Posted 24 Oct 2007 13:43
  • Modified 24 Oct 2007 13:45 by poster
  • By Pacho
  • joined 24 Oct'07 - 1 message
HC
more than likely a bad resting directional contacter but dont rule out the switch and the wiring.possable coil but the rearly go bad and if it is the coil its best to change the entire directional contacter because it proably is worn out. and more than likely the driver built in the card is okbut you can check that at tb5 and tb6.good luck.but it is a contactor tip more likely lol
  • Posted 11 Nov 2011 10:35
  • By gary1234530
  • joined 11 Nov'11 - 2 messages
dont let your kids become a forklift repairman
Code 23 is a posible contactor code. Check coil resistance, should be between 10-15 ohm. Recheck wiring to coils and from coils to card (wires#23 and # 27) to B plug on Card. Contactor tips on F&R contact assy that have high voltage drop across them can cause Code 23 or 24. Code 53 can be caused by tips also during plugging. If you have no forward, check normally open forward tips, and also check normally closed reverse contact tips.
  • Posted 22 Feb 2008 14:39
  • By carl_v
  • joined 12 Oct'07 - 76 messages
  • Posted 22 Feb 2008 14:36
  • By carl_v
Big Joe PDR30-154
USD7,500
Aichi RX07B
