won't run
the engine won't run.
When the key is in crank position the engine starts and runs as long as the key is held there.
When I let go of the key and the key is in run position the engine dies.
This lift had this issue before, and a different distributor was installed, and seemed to fix the problem at that time.
I will have this lift tomorrow to look at. any help is appreciated.
  • Posted 20 Feb 2014 08:09
  • By bowlerwa
  • joined 24 Aug'12 - 35 messages
  • Washington, United States
Can I get a wiring diagram of this it has been butchered from attempts to repair HYSTER YALE TECH.
  • Posted 13 Dec 2016 11:55
  • By lemuel_w
  • joined 13 Dec'16 - 1 message
  • Virginia, United States
Thank you the black wire at the harness side was broken into
  • Posted 17 Jun 2015 06:39
  • By jerryb
  • joined 23 Jul'14 - 7 messages
  • New Mexico, United States
if i had worked on the truck i worked on yesterday and knew what i found out on these trucks i may have suggested looking at the ignition wiring. Yesterday i had one of these that would start and run but ran crappy when accelerated, missing and cutting out....
turns out it was the same problem that you found, the wires to the distributor were previously repaired with a half-aced splice job and the wires were coming apart and had rubbed and gotten exposed.
I repaired the wiring and the truck ran like a champ afterwards ;o)
good job bowler
  • Posted 5 Mar 2014 02:15
  • Modified 5 Mar 2014 02:15 by poster
Problem was the wire to the Distributor. The shielding was touching the wire.
thanks guys
  • Posted 5 Mar 2014 02:01
  • By bowlerwa
I'm have not had time to look at it yet. hopefully next week.
  • Posted 22 Feb 2014 06:20
  • By bowlerwa
Check the keyswitch also
  • Posted 21 Feb 2014 04:52
Thanks both of you.
I will look at it in the direction you guys suggest.
I will also let you know the outcome.
  • Posted 21 Feb 2014 02:06
  • By bowlerwa
I agree with rogeriwt but also check the new distributor. I have had multiple dist issues with these trucks where the tach pickup stops working- just because the dist is newer don't disregard it as a possible cause
  • Posted 20 Feb 2014 23:59
  • By bbforks
Check the wires harness at the distributor. They are known for breaking the small wire which send the tack signal to the ecm to run the truck. If the small wire is broken Toyota offers a replacement. If you try to repair it be careful because it is a shielded wire and if you crimp the shield in the connector it will have the same problem.
  • Posted 20 Feb 2014 12:37
  • By rogeriwt
Briefs United States
