Cat EP12KRT
Hi there
Can anyone help, I've got a six flash fault no drive no hydraulics.
Trucks got a Zapi Combi Sem-2 controller, contactor doesn,t close.
Thanks
  • Posted 7 Jan 2014 07:26
  • By kevtwad
  • joined 5 Mar'11 - 76 messages
  • Northumberland, United Kingdom
ok after a simple google search on the zapi sem2 i found this for you
6 flashes can mean either one of the following 4 things
1) CONTACTOR DRIVER Problem with a Contactor Driver in logic.
2) COIL SHORTED Short Circuit of Contactor Coil.
3) DRIVER SHORTED Short Circuit of Driver supplying the Main
Contactor.
4) CONTACTOR CLOSED Main Contactor contacts CLOSED. Contacts
may be welded or mechanical failure has
my guess is you have either welded tips on the line contactor or its shorted and probably needs to be replaced.
occoured.
  • Posted 11 Jan 2014 07:24
thanks everybody not going back to the truck till next week when i'll check for a code then
cheers
  • Posted 11 Jan 2014 05:31
  • By kevtwad
Kevtwad
If this truck is equiped with a zappi combi controler it must have a BDI gauge on the Dash and if there is a fault with the truck then faullt codes will be displayed on the bdi in the frm of AL codes Like AL06 or AL17 but if you are referring to the flashing lights around the bdi gauge that end with a red ligfht at the bottom of the gauge then I would say you either had a battery problem or bad battery leads or a poor connection from the battery.
I would like to wish all members of this forum a happy new year and may you all have a good one.
Regards Titus
  • Posted 8 Jan 2014 22:03
  • By Titus
  • joined 6 Jul'10 - 185 messages
ya edward i noticed they have different models over there, some are similar to here but then they have some we dont
  • Posted 8 Jan 2014 10:43
Swoop, European trucks...
  • Posted 8 Jan 2014 09:51
Ep12 and 15 krt models been around for ages all 24v 15 is the biggest in the krt range what code have you on the display alan
  • Posted 8 Jan 2014 06:22
  • By alanmitsi
  • joined 8 Aug'13 - 151 messages
  • essex, United Kingdom
EP12KRT?
never heard of this model
the lowest model i know if is an EP16 series.
are you sure on this model? is it new?
got a serial number?
  • Posted 7 Jan 2014 21:19
ohm coil for short if ok check for b+ and supplied negative to the coil on start up. pretty straight forward.
  • Posted 7 Jan 2014 09:53
  • By stam
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Dallas, TX or Lexington, KY, United States
Highland, IL, United States
Orlando area, United States
Tacoma, WA, United States
