Hyster H90 Not starting.
I have a 1994 Hyster H90XMS serial# L005V01601B with the GM 4.3 LPG engine. Starter is only clicking, replaced starter and battery. This did not solve the problem. I then noticed the 50 amp alternator fuse was blown I replaced this tried to start it again cranked slow then immediately blew the fuse. Could this mean a shorted alternator?
josh.olivia atgmail
  • Posted 24 Nov 2013 10:16
  • By brokendirtbike
  • joined 28 Sep'11 - 22 messages
  • Washington, United States
Hard working with little time for hard playing
josh dot olivia gmail
Hi , you can set the positive cable of battery directly only on the starter and check starter wil rotate without starter relay.
  • Posted 27 Nov 2013 06:30
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
If you bypass the wiring & jumper right to the starter solenoid start terminal what happens? I see this symptom all the time with Toyotas. The solenoid doesn't get enough power thru the wiring harness to activate the solenoid properly. Wiring in a relay to give the solenoid direct battery voltage solves the problem
As far as the alternator- it does sound like it's shorted
  • Posted 27 Nov 2013 01:39
  • By bbforks
Cables resistance is good. Battery only drops to about 11.2V during attempted start. The alternator fuse that keeps blowing makes me lean towards that. The alternator, pump, and engine turn freely. Thanks for the help.
  • Posted 25 Nov 2013 14:37
  • By brokendirtbike
Yes it is possible that either your alternator bearing is seized up or the water pump or idler/tensioner bearing is seized up and causing your issue, but I am betting that its in your cables as I stated earlier......KEEP US POSTED as to what you find
  • Posted 25 Nov 2013 08:43
  • By kevin_t
Yes , you can disconnect the alternator from the battery , it is possible it is stuck and they take 70-90 ah from starting and then you have a problem with starting.
I have fix this problem by a linde H80 with perkins engine, same problem , new starter and battery but also clicking , it have a alternator fault
regards
  • Posted 25 Nov 2013 03:50
  • By gc_d
Regards gc_d
I would first look at your power cable from the battery to the starter for corrosion in the cable and also check your ground cables.....do a voltage drop test to see where your resistance is.....what does the battery voltage drop to while cranking? Sounds like corrosion in the cables or a poor ground cable from the block to the battery
  • Posted 24 Nov 2013 11:56
  • By kevin_t
Highland, IL, United States
Orlando area, United States
Dallas, TX or Lexington, KY, United States
Tacoma, WA, United States
