have sussed if you let the truck go onto standby then hold i button password screen appears and you are in, unless you have e056 (lift button fault) seems to stop atc from beeping supose you have to clear fault first will disconnect buttons next time to see ! but have substituted old head unit so not too hopefull
is there any way to fool the atc unit into reset to default, there is a battery on the atc card if i remove it will it default the settings thanks for your help
Hello trevb
Wat you need!!
Info about pll200
When you have display its the master of the truck you can't whitout display make change's on controller you need the display.
code 002468 service code
start code new 3333 old 2222
You need the tree for service let me now
I will help
John.
ok i have found when replacing load wheels bumping of truck changes display back to enter code , searh in settings select key switch, no then truck starts as normal with log in code, switch it back to key ,yes and i cant use key pad again but how do iget back into controller to change it back, cant see option on menu tree for zapi cant get any info from atlet
