manitou m50-2h/t2 - 100
how can you lift the cab on this unit
  • Posted 21 Aug 2013 06:09
  • By dale_d
  • joined 9 Aug'13 - 6 messages
  • Missouri, United States
dale davenport
ok thank you will give that a shot
  • Posted 21 Aug 2013 07:23
  • By dale_d
If its like the M40T that I work on......open the hood over the engine....on the back of the cab should be two large nuts W boss's around them remove these and the cab should lift up....l
Never had the cab up on the one I work on but do know these two nuts are to be removed to lift the cab
  • Posted 21 Aug 2013 07:05
  • By kevin_t
The black box flight recorder was invented by Australian scientist David Warren in the mid-1950s. While initially met with indifference in Australia, his invention gained international recognition, particularly in the UK, and is now a mandatory piece of safety equipment on all commercial aircraft.
Ottumwa, IA, United States
Atlanta Savannah Orlando Tampa Jacksonville West Palm, United States
St. Louis, MO, United States
