RAYMOND EASI DR30TT
Seri: EZ-B-00-17750 Lift, traction is ok but tilt can not.I check tilt motor 36VDC Damage but i don't know capacity of this motor.How many watts?Who's can help me
  • Posted 17 Aug 2013 01:55
  • By pham_s
  • joined 15 Dec'12 - 81 messages
  • 12, Viet Nam
phamquocsy9@gmail.com
Stam,because if's the first time i repair this model so i don't have much information, i forgot the switch LS at the PEDAL is damage, can not stop.can i change the same swich ( not RAYMOND),Do you have shop manual of this model?
  • Posted 18 Aug 2013 10:17
  • By pham_s
  • 12, Viet Nam
is the reach working is power steering working? if so the aux motor and pump is ok. as i said before i believe you have bad wiring. there is a small cable (#18/4) that runs through the reach assebly and provides power/ground for the solenoids behind the load backrest, these solenoids are for tilt/sideshift. the cable is bent up/down constantly as you reach and retract the forks causing it to wear and break frequently. check this cable!
  • Posted 17 Aug 2013 21:22
  • By stam
Stam, aux motor is damage, carbon brush...very bad.Run,Power steering, lift is ok but can not tilt, sideshift.the power supply to Aux motor when i push the button is 37.8 volt
  • Posted 17 Aug 2013 09:16
  • By pham_s
  • 12, Viet Nam
the tilt motor is called the aux motor, it runs power steering/tilt/sideshift. so if you have power steering the motor and pump is ok. check the wiring going from the carraige to the solenoids behind the load backrest.
  • Posted 17 Aug 2013 07:17
  • By stam
edition #1242 - 7 August 2025
In this week’s Forkliftaction News , we take a closer look at the main theme coming out of the recent CeMAT Australia event in Sydney: automation; why some are holding back and why not everyone will automate... Continue reading
Ice 28INCH-AUTO-SCRUBBER
USD8,350
Hangcha CPYD35XH21F
Flesherton, Ontario, Canada
USD8,350
Hangcha CPYD35XH21F
October 15-16, 2025 - Las Vegas, United States
November 13-14, 2025 - Berlin, Germany
