Code truck disabled
524245-3 is the code installed a new seat switch any help would be appreciated.
  • Posted 26 Mar 2013 03:37
  • By alan_d
  • joined 11 Sep'11 - 7 messages
The seat has a 6 pin connector harness which runs thru the engine cover the harness from the truck side has a 6 pin and a two pin connector.
  • Posted 26 Mar 2013 07:40
  • By alan_d
I'm a bit confused. Does the new seat have a switch in the bottom of it with wires coming out of the switch and a 2 pin square shaped connector on the end of the wires? That should connect to the 2 pin connector from the forklift that comes through the hole in the engine cover, right under the seat. Where is the 6 pin connector, inside the engine compartment?
  • Posted 26 Mar 2013 06:04
They purchased the truck from an auction with no seat on it now I'm stuck trying to figure out what is wrong with it the plug, 6 pin is the same but there is a two pin that is on the truck that is tied off to the harness that goes to the seat switch bu no where to plug it in the seat.
  • Posted 26 Mar 2013 05:47
  • By alan_d
Did the truck stop working after you changed the seat? Is the wire harness plug on the new seat the same as the old one?
  • Posted 26 Mar 2013 05:43
It was a replacement seat from Yale how would you know the difference I know the difference?
  • Posted 26 Mar 2013 05:30
  • By alan_d
Did you use the special $100 Yale proximity seat switch that is used on these trucks? It is not a simple standard on/off seat switch like most other trucks have, even though they look the same.
  • Posted 26 Mar 2013 05:19
2 wires ? 5 volt signal?
  • Posted 26 Mar 2013 04:09
  • By alan_d
2 wires 5volt 1 wire signal. between+5volt and signal resitant or dash lamp to disconect
  • Posted 26 Mar 2013 04:01
  • Modified 26 Mar 2013 04:08 by poster
  • By AAPEE
  • joined 28 Aug'12 - 76 messages
  • Brussels, Belgium
SMV (Konecranes) 12-1200B
Ice 24INCH-AUTO-SCRUBBER
USD6,396
Libiao Robotics
USD6,396
