Code 100-2
Wondering what this code is? Thanks.
  • Posted 2 Mar 2013 07:20
  • By ATK1
  • joined 27 Jan'12 - 74 messages
  • South Dakota, United States
allenk@ntlifts.com
DTC 100-2 - Engine Oil Pressure OORH at Stall
PROCEDURE OR ACTION:
1. Ensure truck power is OFF.
2. Disconnect the indicated connectors at sensor and VSM or applicable ECU.
3. Change DMM to volts scale.
4. At the sensor harness connector, measure the voltage across the sensor signal wire (+) and the negative (−) terminal of the battery.
Is voltage approximately system voltage?
YES: The signal wire is shorted to an unswitched battery source. Refer to the appropriate Diagrams and Schematics YRM for unswitched battery voltage sources. Locate and repair/replace shorted wire/connection. Refer to the appropriate Wiring Harness Repair YRM.
NO: Go to Step 5.
5. Turn truck power ON and repeat Step 3.
YES: The signal wire is shorted to a switched battery source. Refer to the appropriate Diagrams and Schematics YRM for switched battery voltage sources. Repair or replace shorted wire. Refer to the appropriate Wiring Harness Repair YRM.
NO: Go to Cause E.
  • Posted 17 May 2013 08:10
  • By LilBitCrazzzy
  • joined 8 May'13 - 8 messages
  • New Mexico, United States
MEDLEY MATERIAL HANDLING COMPANY
Operations Manager
Maxlion ESD15M
Aichi RX07B
Michel Denis Michel Denis
