Platinums Running Bad!!!!!!!!!!
I you have a newer Nissan H21/H25 you must drain the tar out of the regulator. The truck will seem to need a tune up, but it starving for fuel. There is also a small filter and oring in the fuel electronic lock off. There is also screen filter that should be cleaned, we use brake cleaner. Nissan suggestes replace this filter the first 200 hours, we are doing that and once a year.
If anyone needs help on a nisssan Parts or Service drop me a line.....
[email address removed]
  • Posted 30 Jun 2007 12:34
  • By jim_p
  • joined 26 Aug'06 - 18 messages
used this info today with a LPG truck, did not fix the problem but it did help rule out some things... thank you very much for the info.
  • Posted 30 Apr 2009 10:29
  • By Jan_Haayer
  • joined 4 Mar'09 - 18 messages
  • Nova Scotia, Canada
