code a6
can anyone help me with this error code a6 on the screen
  • Posted 13 Feb 2013 21:02
  • By mladen_e
  • joined 19 Feb'11 - 9 messages
  • BiH, Bosnia And Herzegovina
mladjobubi@hotmail.com
Thank you very much.Do you perhaps have a service guide?I would be appreciate if you sent me.Thank you in advance.
  • Posted 14 Feb 2013 22:28
  • By mladen_e
Code a6 : material handling switch installation abnormality. Other words means you need to check the switches on the lift, tilt and side shift levers. check them for proper adjustment, ohm switches out to see if they are good, check the wiring to make sure they are reaching cpu and no shorts , if wiring and switches all test good you have a bad cpu board ,hope this gets you in the right direction, 90percent of the time you will find a switch has failed
  • Posted 14 Feb 2013 12:33
  • By fixnproblems
  • joined 19 Jan'13 - 66 messages
Briefs United States
