Code 236
Keep getting Code 236 "Input Mismatch" on electric TMX20 with Zapi controllers.
Any thoughts??
Have changed out controllers only to have code reappear.
Anybody have issues like this before??
  • Posted 12 Feb 2013 13:16
  • By UncleSi
  • joined 12 Feb'13 - 135 messages
  • Manitoba, Canada
Message for Tom_p I didn't receive your email with the info regarding the controller mismatch fault resulting in the truck (when steering) acting as if the differential has jammed. thanks again in anticipation. Sandy.
  • Posted 15 Sep 2019 05:30
  • By SMcG
  • joined 18 Feb'18 - 30 messages
  • Angus, United Kingdom
I also keep getting this error code " 236 mismatch " , would any one give a solution for this fault.
My controller is zapi FZ5035 fitted on Clark EPX20S
Thanks
  • Posted 12 Jul 2019 09:34
  • By amr_k
  • joined 12 Jul'19 - 1 message
  • Sudan
check your email for some more info.
You can use the Zapi to confirm all your switches are closing in the tests menu. Using the old Zapi hand set is clunky but does work.
That said,recently the same symptoms and fault code you describe were found to be corroded and broken seat enable wiring under the battery.
  • Posted 19 Feb 2018 06:42
  • By tom_p
  • Alberta, Canada
Hi Tom P
Can you still provide the fault finding info for the Clark TMX 15 with Zapi Dual AC controllers This is a 4 wheel forklift with two drive motors.
Hi Tom_p
Didn't get your the email about the info to try and resolve our mismatch controller fault. When trying to steer the truck it acts as if it has differential lock.Thanks in anticipation. Sandy
  • Posted 19 Feb 2018 02:46
  • Modified 15 Sep 2019 05:20 by poster
  • By SMcG
236 fault is a Input mismatch between slave and master controller.
Check, directional, brake , seat, accelerator switch and wiring. Had same fault and the problem was enable wiring corroded under under battery.
  • Posted 18 Feb 2018 12:25
  • By tom_p
  • Alberta, Canada
Did anybody get to the bottom of the code 236 with mismatch on dash?
  • Posted 18 Feb 2018 08:34
  • By SMcG
The new ZAPI controller fixed "my" 236 problem.
Operators are running the batteries down REALLY LOW constantly !!
The cables that run to the motors from the boxes are all overheated, crispy, and terminals on ZAPI boxes are melted... high amperage ?? I'm assuming.
  • Posted 14 May 2014 01:27
  • By UncleSi
  • Manitoba, Canada
Hi guys
i have the same problem (error code 236) on TMX 15 CLARK truck
have you found the solution ???
Thanks
  • Posted 11 Mar 2014 19:14
  • By olivier_b
  • joined 11 Mar'14 - 1 message
  • france, France
Nope!!!
Talked to a guy at Clark factory.... he says its gotta be controller... So tomorrow she gets a brand new controller - not another freaking Flight Systems rebuild!!
It's an expensive roll of the dice !!
  • Posted 4 Mar 2013 09:13
  • By UncleSi
  • Manitoba, Canada
Have you resolved your 235 and 236 fault yet? If not, i do have some trouble shooting info.
  • Posted 3 Mar 2013 05:38
  • By tom_p
  • Alberta, Canada
error code 236 and 235. please send me the details.
equiptecworld at gmail dot com
  • Posted 26 Feb 2013 16:45
  • By lishoy_t
  • joined 29 Oct'12 - 70 messages
  • dubai, United Arab Emirates
my email is in my profile
you should put your email address in your profile
  • Posted 13 Feb 2013 19:10
  • By forklift_brazil
  • joined 15 Nov'12 - 108 messages
  • rio de janeiro, Brazil
tecmanuais@yahoo.com.br
skype:hyster.brasil
How do I send you a private message ??
  • Posted 13 Feb 2013 11:59
  • Modified 13 Feb 2013 12:00 by poster
  • By UncleSi
  • Manitoba, Canada
what's your email?
  • Posted 13 Feb 2013 05:24
skype:hyster.brasil
Oxford Ct, United States
Columbus, United States
RAEDER-VOGEL
edition #1257 - 20 November 2025
