Vibration
I have a 7FGU30 that I service. The challenge is engine vibration just above idle. Unit has the 4Y engine w/ ECS system installed- can't seem to adjust much without the computer compensating. The problem with the vibration is that it's literally shaking the wiring harness to death. I've had multiple service calls due to the wiring braking. I priced a wiring harness today & at $5,500.00 ( yes- that's correct) the customer isn't to happy.
Is there any way to deminish the vibration? The older Toyota's with the 4Y vibrate but usually I can adjust the vibration out- no such luck here- any ideas?- thanks
  • Posted 16 Jan 2013 13:30
  • By bbforks
You need to e-mail me. My e-mail address is in my forum profile, yours is not.
  • Posted 10 May 2013 23:30
  • By L1ftmech
  • Tennessee, United States
YES PLEASE
  • Posted 10 May 2013 22:45
  • By ben_k
  • joined 26 Apr'13 - 3 messages
Do you still want the connector list?
  • Posted 10 May 2013 09:10
  • By L1ftmech
removed the top plate on the tranny and switched the solenoids, no change. should have ohmed out the wiring conection from the solenoid to the wiring harnes connector.
  • Posted 10 May 2013 07:04
  • By ben_k
did you try to swap the coils? It could be a bad coil.
  • Posted 26 Apr 2013 08:45
  • By rogeriwt
Could I possibly get the full list of connectors? We are experiencing aproblem with fuses blowing when shifting into forward(not reverse) Any suggestions? Thanks
  • Posted 26 Apr 2013 04:05
  • By ben_k
Toyota has actually made available a fairly comprehensive assortment of replacement connectors for the 7F models with their infamous 4Y engine. I say infamous because the engine is well known for its rabid shaking. You could even say it is Toyota's biggest "mover and shaker".
I am providing a partial listing of the most "failure prone" connectors in this post because not all Toyota parts guys are aware of the availability of these connector kits.
These kits are not what you would call "cheap" as the least expensive one rings up at around $35 USD, but that is a minor blow compared to a complete harness.
I also want to add that Toyota has not yet developed a similar replacement connector group to cover the 8F models (I have already inquired) but that could be forthcoming as the 8F models with 4Y ECS engine can do the shimmy as well as their older sisters when they get mature enough.
The complete list of connectors includes sensors/solenoids for most SAS functions on the 7F models as well, I'm just not going to bother listing all those here. I can provide the whole list if anybody needs, just e-mail me.
Wire harness connector pigtail kits for Toyota 7F models with 4Y engine. Connectors are for the HARNESS, not the actual component or sensor and come with short (around 8 inches) lengths of wire already in the connector body. You also get enough bare metal crimp splices (which you might not want to use, soldering is best) and heat shrinkable tubing for the number of wires featured in each connector for the specific component.
Throttle motor connector (4Y ECS engine).....90957-U9006-71
2 wire (non-heated) O2 sensor.....90957-U9007-71
Alternator.....90957-U9008-71
MAP sensor.....90957-U9009-71
TWC Coolant sensor (green sensor color).....90957-U9010-71
Distributor.....90957-U9011-71
LPG Injector.....90957-U9012-71
LPG Slow path fuel solenoid.....90957-U9013-71
LPG Main fuel solenoid.....90957-U9014-71
  • Posted 21 Mar 2013 02:05
  • By L1ftmech
Thanks fixnproblems- the metal cap & adjustment on the regulator was the key- the things runs smooth as silk now!
  • Posted 20 Mar 2013 23:03
  • By bbforks
Those units are notorious for having that problem due to heavy emissions and a light aluminum transmision casing. First check ignition system cap ,plugs, wires ect. Then remove the throttle body and clean the throttle plate and housing (they always have lp gum on plate and housing). check timing to mke sure it hasnt been tampered with. Remove the right foot pedal step and you will see a small plate,remove and there will be a **** for idle adjustment. adjust but dont max out it will throw a engine code when trying to start. then the lp regulator has a metal cap on top that can be knocked out. that will give you a little more low idle adjustment. hope fully this will help good luck
  • Posted 19 Jan 2013 18:22
  • By fixnproblems
  • joined 19 Jan'13 - 66 messages
Engine vibrates in nuetral & d/r.
  • Posted 17 Jan 2013 22:53
  • By bbforks
Have you checked the driv shft for play?
  • Posted 17 Jan 2013 13:03
  • By rogeriwt
