code 51 clark tmg15
Is there someone who knows what 51 code means?
The battery is fully charged.
I need someone to help me, I have no information¡¡¡¡
  • Posted 15 Jan 2013 10:54
  • By luismario_z
  • joined 7 Aug'08 - 14 messages
  • Jalisco, Mexico
servicio@grupozamsa.com
Thank´s Ivan I´ll check it out
  • Posted 17 Jan 2013 07:54
  • By luismario_z
  • Jalisco, Mexico
Check if you do not have shorted controller. Check wire #24 going from terminal #17 on Master Controller. Should feed - to line contactor coil. Pos comes from key switch.
  • Posted 17 Jan 2013 07:31
  • By ivan_j
  • joined 16 Feb'11 - 65 messages
  • Posted 17 Jan 2013 07:23
  • By ivan_j
I'l check it out and I' l keep you posted
Thank you!!!!
  • Posted 15 Jan 2013 13:07
  • By luismario_z
  • Jalisco, Mexico
Thank you!!!!
  • By luismario_z
  • Jalisco, Mexico
SYMPTOM
Line contactor does not close when capacitor does not precharge.
POSSIBLE CAUSE
Status code -51 may display if the key switch is open and closed too quickly after the Line contactor has opened due to a PMT fault. To correct, turn key off to 10 seconds before turning back to the on position.
Low or volts at LP1/RP1 wire #2
* Check wire #2 for open circuit. Repair
wire, if necessary.
Improper wiring of an accessory to the controller side of Line contactor. Check for drain from B+ buss bars.
Defective control.
* Replace controller unit.
  • Posted 15 Jan 2013 11:25
  • By ob1kenobi
  • joined 22 Nov'10 - 153 messages
  • SAN P.SULA, Honduras
Mike Barker Mike Barker
President and CEO Swisslog Americas, Swisslog
Vice president, Newgentech Material Handling India
Sales representative, Alabama and Panama City, Thompson Lift Truck
Chief marketing officer, Bobcat Company
Hangcha CPYD30XH21F
Flesherton, Ontario, Canada
JLG G12-55A
The origin of "love" as the score zero in tennis is debated, but two main theories prevail. One suggests it's derived from the French word "l'oeuf" (egg) which resembles the shape of the number zero. The other proposes it's related to the Dutch word "lof" meaning "honour" as players might be playing for honour when scoreless.
Hangcha CPYD30XH21F
JLG G12-55A
