Cat NOR30 Code 81, Intermittant, pot or cable?
Cat NOR30
2ML-03026
Orderpicker
2500 hours
I have a reoccuring code 81 during opperation, intermittantly, at times, consecutively, other times, days without a fault(almost 6months now)
I have replaced the Lift/Lwr pot, twice and re learned (aftermarket parts) and this resolved the issue for a short period. After tracing, checking and testing, I installed an OEM lift/lwr pot, performed learn, and the fault was resolved, so I thought, 3 months later same issue.
I have inspected and marked all over mast cables at fault height(fault occurs when lowering) it faults at a height of 50 to 97 inches, the mast cables look fine but can be decieving.
When code 81 occurs, a key off/on cycle will bring unit back into service untill the next fault, (as soon as lowered, or two days later). The lift/lwr pot is within the spec range, voltage, at nutral, lift max and lwr max, so I am leaning towards the over mast cable. But this is an expensive leap of faith, (I have attempeted to measure a voltage drop across the mast cable at the time of fault, but it will not cooperate and fault for me)
Any ideas that I am not thinking about? Or help push me off the edge to replace the over mast cable.
  • Posted 20 Nov 2012 04:15
  • By gwmtech
  • joined 20 Nov'12 - 4 messages
  • Manitoba, Canada
if the wiring is in good shape the voltage variation shouldn't be that much,.5v at the most. If your getting more than that then you have bad wiring or bad connection somewhere, or worse case a bad carriage board. Also check to see if any of the height limit switches are around the height you specified earlier, maybe one of them is glitching the system causing it to throw the code. I'm still banking on the pot just being out of range but since I'm not there to see it for myself i cant say with any certainty.
  • Posted 26 Nov 2012 15:04
  • Modified 26 Nov 2012 15:13 by poster
Swoop, when I say sample the displayed voltage is not as accurate as following the readings through a Fluke 79, say. Also, those voltage readings pass though the handle harness, through the carriage control card, over the mast to the vehicle mgr, are processed there, passed BACk over the overmast cable into the carriage control card AGAIN and to the display for you to see...alot of room for error wouldn't you say?
  • Posted 21 Nov 2012 23:58
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
kevin,
maybe i chose an incorrect term for that
yes ohming is a form of resistance checking but i use another method that was mentioned, a continuity check which also can show any resistance in the circuit. A good clean circuit will read close to 0 but if there is any anomaly in the path it will show a value greater than 0, basically the same as ohming does.
and as far as the A04 test it is there, when you get into the menu you can go to each segment and should be able to change it till it reads A04. I think when it first comes up it might read I00 or something like that if i remember correctly. Since i'm not looking at a manual right now or have one in front of me i'm trying to go from memory here.
joe,
and as far as the comment about not trusting the analog 'in-truck' tests? well this is what the truck is seeing and it reads that voltage to calibrate itself and guage the values on which the truck runs. The TMM is monitoring this voltage the way you see it there, so why wouldnt you trust it? Speaking of being bit, i've set many a potentiometers with a vom only to have to reset/readjust it after i installed it because the system was seeing it differently. Part of adjusting this and calibrating it to the system is having the test mode up on the console before you even remove the control handle from the circuit, if you try and set the pot externally and then start up the truck afterwards to go into setup mode to calibrate the system to it, the system will see this and will not start up correctly because it is not seeing the right voltage range and you will play **** trying to gain access. Sometimes the 'old school' ways just do not work, especially on these trucks.
Of course if this has the later system on it the access keypad/display is on the dash and not like the ones that have the remote display box mounted over the crossbar on the mast like the older ones, those require input solely from the control handle horn button and pot's, this being the only way to control the input to navigate the menu system. I'm farily certain they revised that keypad input to eliminate this problem that the older units had to simplify the calibration.
  • Posted 21 Nov 2012 16:37
  • Modified 21 Nov 2012 21:39 by poster
I've learned over the years to not depend on the in-truck analog tests as they only "sample" the voltages and I've seen many a tech that took these readings as gospel and got bit. Also, when I do an ohm test on an overmast cable I disconnect both ends, attach negative lead to say the red wire at one end and positive at the other. strum the cable like a guitar string at the point you think the problem is (this duplicates the bouncing around of the cable during lifting/lowering). If you have good continuity, disconnect negative lead and connect to another wire, leaving the positive on the red and repeat the strumming. Repeat this procedure through all the wires of the cable to verify that you aren't getting a short between wires that could cause your problem. I've had a truck lose wire guidance when lowering and honking the horn at the same time due to this.
  • Posted 21 Nov 2012 07:00
  • By joe_d
"now from the sounds of it you may be in the right area but maybe your testing method for checking the mast cable is not correct? instead of ohming the cable wires try doing a resistance check instead. generally if there is a break in a wire there will be higher resistance that will show up that ohming may not."
Swoop,have one question on this statement Ohming and resistance checking are one in the same are they not? Ohms is resistance? Did you mean voltage drop test in this statement?
  • Posted 21 Nov 2012 02:26
  • By kevin_t
Here's an additional tidbit
I'd love to run the analog test A04 but it isn't an option in the analog test menu. I will be visiting this job again in the next day or so. I will note the software version and my avail
options for tests. FYI I do have both password and superword. And have been through all menus and am fairly proficient with these type of on board tests, and procedures.
Weather this info changes anything. But hey, if I can confuse anyone else over this unit, the better, the more the merrier lol. Thanks ahead of time for any input.
In the meantime I have ordered another OEM pot in attempt to rule out the most common failing part. I will follow up with any more info as I find it.
  • Posted 21 Nov 2012 01:01
  • By gwmtech
  • Manitoba, Canada
first off using 3rd party parts isnt always a good thing , always try and use OEM parts if availaible.
when installing the lift pot it is recommended to 'precenter' the pot to 653ohms, then using the below mentioned voltage ranges and having the truck in test mode set it center voltage of the expected ranges, the 653ohm range should have it farily close. Then once set run the learn mode test to calibrate the TMM to it.
secondly if your just testing then try going into the 'analog' test mode and go to test A04 and check the lift/lower pot voltage and see if it is staying within the expected ranges for this circuit which would be 0.156v - 4.84v , anything above or below this reading would trigger this code.
Also i noticed they have a revised OEM part number for the travel and lift pots, unfortunatly the service gram does not specify which one is which , i'm sure the parts person can determine this though when he checks the number
SE000258 and SE000267
the other suggestions for this failure would be:
incorrectly adjusted liftpot
control handle wiring may be faulty
bad carriage wiring board
mast cable (you already suspect this one)
learn mode needs to be run (you already did this also)
control handle may be moving beyond designed parameters due to a mechanical problem
and lastly a bad vehicle manager (lets hope its not this one)
Just a thought
good luck
  • Posted 20 Nov 2012 22:26
  • Modified 20 Nov 2012 22:30 by poster
