Code 522655
We have a S50FT F187V06547D unit that has a Temperture Fault that pops up on the dash. The code is 522655. Can anyone tell me what this could be?
Thanks
Andy
  • Posted 30 Aug 2012 01:42
  • By chevelless502
  • joined 11 Dec'11 - 9 messages
  • Illinois, United States
This code comes up when the engine has idled for too long as well when the fault shows drive the forklift like normal & it will go away. If you have a machine that allows you to check fault logs you will see it regularly. 660 logs on a machine with 2457 hrs. Nothing at all to worry about unless it is showing up in normal operation.
  • Posted 25 Oct 2015 13:18
  • By badgav
  • joined 19 Jul'13 - 2 messages
Go hard or go home.
the description of your code is in the post just above this one.
start with clearing the code and seeing how quick it returns, then making sure your air filter is new, and has not been blown out too many times, then do a good tune up.
  • Posted 21 Mar 2014 20:04
522655-1 code. What does that mean and how to I repair it?
  • Posted 21 Mar 2014 07:33
  • By sako_k
  • joined 12 Mar'14 - 17 messages
Sako1sk at yahoo dot com
522655-0 short term closed loop correction bank 1 less than nor.-40% ritch e.op. 522655-1 short term c.l.c bank greater than nor+40% lean e op
  • Posted 31 Aug 2012 03:58
  • By AAPEE
  • joined 28 Aug'12 - 76 messages
  • Brussels, Belgium
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
