c500-s100, blown headgasket, what motor is this??
i have an older clark c500-s100 with an inline 6 cylinder flathead. it has a blown headgasket it would appear (water in oil), though i suppose it could have a cracked block aswell, anyways what is this engine? (so i can order parts)
  • Posted 21 Aug 2012 04:00
  • By al_n
  • joined 21 Aug'12 - 5 messages
  • Arizona, United States
Showing items 1 - 16 of 16 results.
I hear ya, I would still pressure check the cooling system. It could be a hydraulic pump leaking into the crankcase, or the P/S pump.
Usually (every time in my experience of 30 years) when a continental flat head has a faulty head gasket, there is a compression loss in 1 or 2 cylinders. I've never had a coolant leak into the crankcase, but there's always a first.
  • Posted 27 Feb 2016 02:13
  • By bbforks
Last time before I changed the oil the level was very overfilled. The level had not gone about full while I left the radiator cap loose.
  • Posted 27 Feb 2016 01:59
  • By mark_130
  • joined 26 Feb'16 - 2 messages
I would pressure test the cooling system before condemning the head gasket. Usually the oil turns a milky brown color, not green.
If you constantly run a continental engine in short spurts (5-10 minutes at a time), the oil will get moisture in it because of condensation inside the engine.
  • Posted 27 Feb 2016 01:49
  • By bbforks
I have a Clark C500 with a 6 cyl. Continental. The oil level has been going up lately and getting green. Changed the oil and loosened the radiator cap. I do not run it for very long at a time where it could overheat and the oil was looking good. Last week I tightened the radiator cap again and noticed the oil is starting to get a green color again. Head gasket or any thoughts?
  • Posted 26 Feb 2016 13:13
  • By mark_130
The old c500 wakashau 4 cyl and f163 I think used a zenith or J&S high pressure system for propane make sure the carb is ok if you are using one of these systems they will drive a fella nuts.
  • Posted 27 Sep 2012 09:07
  • By Dave T
  • joined 6 Nov'10 - 34 messages
  • New Jersey, United States
Yes it needs a thermostat. I've started using Gunk engine flush to clean up the block and head after a blown head gasket repair. I find it works great to clean out condensation/ AF from a leaking head gasket.
  • Posted 9 Sep 2012 14:27
  • By Forkliftt
  • Louisiana, United States
Steve
steve at forkliftt dot com
It would do well to make sure it even has a thermostat in place (and working correctly).
It's entirely possible someone removed the thermostat altogether at some time if chasing an overheat problem.
I remember back in my younger years I sometimes heard somebody say "Just leave the thermostat out, **** it doesn't need one until winter."
  • Posted 23 Aug 2012 11:30
  • By L1ftmech
  • Tennessee, United States
thanks.
  • Posted 23 Aug 2012 09:59
  • By al_n
Compression checks out good- no head gasket issues. Change the engine oil ( I reccomend SAE 30) & run engine at least an hour- let the engine get good & hot. Do this on a weekly basis & it'll bake the moisture out of the engine.
The propane system sounds like it's time for a rebuild. Make sure you're running HD-5 propane ( if you want to keep your propane system clean for as long as possible). I reccomend replacing the propane shut off solnoid, regulator & carb diaphram- total cost is under $500 (if you replace these items yourself). That should keep you up & running.
  • Posted 22 Aug 2012 23:06
  • By bbforks
ok here are todays results... compression is consistent between all 6, between 138-140psi.
also in regards to the throttle issues, if i push the primer button in on the propane valve under the hood, and then throttle it, it's revs up normally.
maybe i am just looking at moisture?
and concerning the brakes...not worried about that right, thats for another day :-) right now it's the water in the oil. and throttle...
  • Posted 22 Aug 2012 07:28
  • Modified 22 Aug 2012 07:29 by poster
  • By al_n
Flat head engine are low compression -not sure of the exact number. The important thing is that the numbers you get are consistent. If 2- side by side cylinders are extremely low, the head gasket is gone.
As far as the 30% throttle issue, could be ignition or fuel. Describe the fuel system (I'm assuming propane), different types have different symptoms. Does it have a choke cable? The fuel line should go from the propane tank to some type of fuel shut off, with a wire or vacuum hose going to it. From there it should go to a regulator, either in the same housing as the thermostat in the upper radiator hose, or off to the side with 2 smaller hoses going to it. from there the hose should go to the carburator. Which of these systems does your truck have?
As far as the muck in the radiator, run some radiator cleaner through the cooling system & see what happens ( you may find a leak, you may not - sometimes folks use "stop leak" in the cooling system which will eventually turn to a muck at the radiator cap- but not always)
As far as the brakes, what are they doing? Your truck has a power booster & disc brake setup inside the rear housing assy. Not a complicated system, just an expensive & time consuming one to service.
  • Posted 21 Aug 2012 22:46
  • By bbforks
trying to add some photo's of the engine but, can't seem to... :-/
  • Posted 21 Aug 2012 14:11
  • By al_n
ok, i will do a compression test tomorrow. what should a flatbed compression bed? (i've never touched a flathead before), also the exhaust has a large hole in it...and if the seat were left up water could have gone right in through the hole.
the engine runs fine at low rpm but dies if you go over....30% throttle?
also i noticed on watery condensation looking stuff in the radiator filler neck.
i just want to get this thing running good for my use. the hydraulics are strong, brakes....could use some work but, the hydraulics are strong.
  • Posted 21 Aug 2012 13:53
  • Modified 21 Aug 2012 14:09 by poster
  • By al_n
Right, bbforks, there really is no way to get water in the oil with a flathead motor. A compression test is a must to prove the gasket is bad.
  • Posted 21 Aug 2012 08:09
Before you do anything, change the oil. these engines are notorious for loading up with condensation in the oil from frequent & short running cycles. Change the oil & let it run- if it needs a head gasket it will run rough (with a miss). I personally haven't seen a continental engine loose coolant into the oil because of a faulty head gasket.
If you do pull the head, make sure you have the head resurfaced- don't skimp here- you'll only have to do the job twice if you do.
  • Posted 21 Aug 2012 08:03
  • By bbforks
Continental F227. Once you get it apart check the old gasket and maybe you will see where the problem is. Also the head should be resurfaced before reinstalling.
  • Posted 21 Aug 2012 06:57
JCB 533-105
Crown CG33P5
Andries Retief Andries Retief
Chief development officer, DHL
Director, ICHCA Australia
CEO, TVH
Sales and operations director, Logitrans A/S
JCB 533-105
Crown CG33P5
CEO, TVH
