Jungheinrich EFG216
Hi all Have a Jungheinrich EFG216 SPGE110-400 ZT traction /drive is running slow. I have been told it could be the motor sensor Would that be speed or temperature and where is it internal or external any help with this would be much appreciated Nick
  • Posted 9 Aug 2012 17:39
  • By nick_c
  • joined 17 Jun'11 - 116 messages
  • south glos, United Kingdom
Sorry Nick I dont know colors you have six wires because four are speed sensor and two are temperature sensor for motor,I think you have two for two motors Sorry but I need you eyes now to see that wiring I know that are wires are 0.5mm.Try to look how they go in motor and try to find supply voltage and signal voltage.
Try to measure and tell me what you do.
Best Regards
  • Posted 17 Aug 2012 03:35
  • By nemanja_k
  • serbia, Serbia
Hi again nemanja
I am sorry to bother you again
I have looked at the connection to the motor today and there are 6 connections
Brown-blue-white-black-black-blue on motor cable and
Brown-yellow-orange-white-black-black on loom
What 2 cables do I test on
Nick
  • Posted 16 Aug 2012 02:42
  • By nick_c
You are welcome my friend
  • Posted 14 Aug 2012 04:31
  • By nemanja_k
  • serbia, Serbia
Yes I understand. I will try that and then write to you again.
Thank you for your help nemanja
  • Posted 14 Aug 2012 04:19
  • By nick_c
when you measure pulse on one channel you will have 11.5 than 12v again11.5 than 12v pulse is same on bout channel and you dont have short cut on channels,or on supply are you understand me?
What are you do?
  • Posted 14 Aug 2012 02:40
  • By nemanja_k
  • serbia, Serbia
Hi again
nemanja_k
Not sure how I measure the pulse can you advise
  • Posted 14 Aug 2012 00:46
  • By nick_c
You guys are the best.Will check that out and get back to you.
Thanks Nick
  • Posted 10 Aug 2012 05:51
  • By nick_c
HI mate
its a good chance its the encoder bearings as if it was a thermal cutback in most cases the truck throws up and error or a dash light indicating thermal circuit.
I have had several EFG with enocoder problems which do not throw up any error codes.
Regards
  • Posted 10 Aug 2012 04:23
  • By elektrodrive
enquiries@elektrodrive.co.uk
That model have sensor bearing in motor traction so from motor go four wiring two of them are B- 12v for supply and two channel A and B.If you think that sensor is problem check power on sensor and if is ok check puls on channels.Usually you must have error but sometimes dont shows.Check and tell me when you do measuring.
  • Posted 10 Aug 2012 00:48
  • By nemanja_k
  • serbia, Serbia
Deborah Baker Deborah Baker
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Tusk 500PGH14
