Code 59
I have this truck and it is giving me fits. I suspected a bad lift amp and sent it out for repair to flight systems. Got it back and now have code 59, no current to steer motor. I changed the diode with no luck. The display blacked out on me when testing so I installed a yale display. I dont know if it makes a diff for electric steering and hyd. steering for the display but I dont think so. Can anyone help. Jim Fos
  • Posted 6 Aug 2012 21:40
  • By jimfos
  • joined 6 Aug'12 - 2 messages
  • New Jersey, United States
code 59 - steer motor current not present
possible causes are:
-broken or loose wire from lift amplifier to steer motor
-damaged or defective lift amplifier
-damaged or defective steer motor
even though the dash displays look the same between the yale and hyster trucks the software in them is different and you shouldnt try and interchange them. The displays store certain information pertaining to the truck and could cause more damage to the system programming in the controller(s) or at least display incorrect information. Also since the display mounts directly on the controller board you may have inadvertantly damaged the 32pin plug or pins, i would make sure this is not the case. Anyhow these boards are very sensative to electrostatic charge and you could unknowingly blow one out if your not careful and always use a ground strap or make sure you are grounded to the truck in some fashion when handling them.
  • Posted 7 Feb 2013 21:13
Did you get your Hyster fixed? We are having the same problem and have tried everything we can think of so far.
  • Posted 7 Feb 2013 04:14
  • By Rodey
  • joined 16 Oct'12 - 21 messages
  • Michigan, United States
Jim Tompkins Jim Tompkins
Sales operations, Heli
Combilift Ltd
Combilift Ltd
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
