Crown sp 3020
Having a fit with a code -24, motor clean. Any ideas?
  • Posted 15 Jul 2012 13:44
  • By 1sharpdog
  • joined 20 Apr'12 - 220 messages
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
replace the directional contactor assembly,
if it was me, the first thing would be to replace the entire directional contactor assembly. What this code means to me is that (most likely, in my experience) the reverse contactor is not pulling in as fast as it should, often due to wear on the guides and insulators. Replacing just the tips most likely will not cure it for long, it is now time to replace the entire directional contactor assembly (maybe not the coils, but the rest of it needs to be replaced). You should find the price of the assembly to be reasonable.
This assumes the rest of the contactors are all in good to 'like new' condition, and that the battery is clean* and well charged, and does not drop voltage more than 10% of the 'at rest' voltage when in hydraulic stall for 3 seconds.
*='Battery clean' meaning that from _any_ power cable to the frame of the truck has at least 100k ohm resistance with the battery disconnected.
  • Posted 16 Jul 2012 00:07
The origin of "love" as the score zero in tennis is debated, but two main theories prevail. One suggests it's derived from the French word "l'oeuf" (egg) which resembles the shape of the number zero. The other proposes it's related to the Dutch word "lof" meaning "honour" as players might be playing for honour when scoreless.
GemOne
