no hydrolics , no drive
all seems to work on machine, key turns on, system check ok. horn works reverse buzzer works, lights work. steering working....when using hyd levers or attempt to drive, display shows to release levers or pedal. customer has informed that machine just stopped during travel and hasnt moved again in a week. i managed to retrieve two codes a14 , a15 although they were brief an only appeared once. any diag tips or manuals would be appreciated......Niehiyu fbrf14-603-630msf serial no -152ac0195
my e-mail is [email address removed]
  • Posted 26 Jun 2012 18:42
  • By horndogg
  • joined 26 Jun'12 - 2 messages
  • Queensland, Australia
i would also go back to those connectors where you used the cleaner and recheck them. Sometimes when assembling the components during production a pin might not get inserted completely and not make good connection between the two connector halfs. Cleaning or moving those around may have completed the faulty connection and this may happen again.
  • Posted 20 Jul 2012 20:43
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Thanks horndogg for keeping us up to date. It's always good to know how it is repaired.
marcb
  • Posted 20 Jul 2012 18:10
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
thanks for your input Mark, no luck though. after much trial an error, bypassing limit an safety switches, tracing wires , i found signals reaching the control board but no signals being sent.a bit of contact cleaner in the connectors seemed to have done the trick ,all working well now. pays to cover the basic checks before over analizing. the vertical arrangement of the control board an connectors tend to gather alot of debri an affect the connection
  • Posted 18 Jul 2012 21:57
  • By horndogg
Hello Horndogg,
Well I would ask your customer to depress the pedal of the battery removel, try the function again and see if works.
Marcb
  • Posted 26 Jun 2012 20:37
  • By marc_b
  • ANTWERP, Belgium
Michel Denis Michel Denis
