stuck in creep mode
Hey guys. Gotta go on a service call tomorrow for a 102 stuck in creep mode. Researched the manual but didn't really find anything. Any thoughts?
  • Posted 12 Jun 2012 08:54
  • By TBG3
  • joined 12 Jun'12 - 1 message
  • Missouri, United States
please post results!
  • Posted 28 Aug 2012 11:11
  • Modified 28 Aug 2012 11:11 by poster
  • By derrick_r
  • joined 28 Aug'12 - 16 messages
  • Utah, United States
handle adjustment, two possession handle making travel slow when the handle is at < 25% if adjusted correctly!
Truck configured for slow acceleration Check truck configuration.
Battery problems Replace battery with fully-charged good
battery.
Binding drive wheel assembly/drive
motor
Jack and block truck. Check that drive wheel spins freely. If
not, repair or replace.
Binding brake disc Check "Air Gap Adjustment"
Bad drive motor
(may test OK with no load, but fail
under load) or worn brushes
Repair or replace drive motor or brushes
  • Posted 28 Aug 2012 11:09
  • Modified 28 Aug 2012 11:10 by poster
  • By derrick_r
brake adjustment
rabit button does not work
depending on the serial # it may have a bad contactor
wiring harness in the handle
belly button damaged
  • Posted 12 Jun 2012 09:36
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
Toyota 8FD45
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Bolzoni SpA (Group HQ)
