Wheel switch not working
Anyone have any experience troubleshooting the drive-wheel circuit on the 20MTs? The motor by the wheel is getting power but when I twist the handle throttle it doesn't work in either direction, turtle or rabbit. I kind of suspect a fault somewhere in the switch circuit. But would appreciate the benefit of anyone's expertise.
Thanks!
Max
  • Posted 27 May 2012 05:09
  • By max_r
  • joined 27 May'12 - 3 messages
those switches are quite reliable
but the bad news is the looms are quite common to fail
  • Posted 27 May 2012 11:17
  • By crownie
  • Victoria, Australia
is the switch at the bottom of the control handle out of adjustment or not working,when you pull the handle down it should push on a switch at the bottom of the control handle
  • Posted 27 May 2012 05:20
  • By kevin_t
Aichi RX07B
Komatsu FD25T17
Hawker Powersource, Inc.
Sue Tomic Sue Tomic
