Error code FL87
hi this is my first time on this site but i have a cat that sometimes gives a code of fl87 and shuts down the transmission can any on tell what this code means thank you
  • Posted 25 May 2012 06:42
  • By bert_m
  • joined 25 May'12 - 8 messages
Thank you all I found the problem
The reverse signal from switch dose not reach to the computer because the wire is disconnected.
  • Posted 16 Aug 2020 06:00
  • By Aous_Shahien
  • joined 21 Jul'20 - 3 messages
  • Syrian Arab Republic
i have a cat that sometimes gives a code of f16 and does not go reverse.
Can you help me
  • Posted 21 Jul 2020 06:34
  • By Aous_Shahien
josh,
you should have 4 to 6 ohms on coils (which you confirmed)
also check voltages
white and yellow wires should read battery volts B+
green wire should be battery neg B-
  • Posted 24 Apr 2015 21:38
To confirm voltages that is
  • Posted 24 Apr 2015 00:34
  • By josh_c
  • joined 4 Apr'15 - 8 messages
Swoop I have a unit p6000 hiving a similar code 85 not 87 my particular unit only throws the no forward code when unit is running and working hard after 1 hour. Truck cools down and no problems leave customer location and call back after unit is running after a while and code returns. My coils ohm out at 6 I'm assuming my forward and reverse solenoid is getting hot and failing what is your input in this would you replace the sokenoid to save the time troubleshooting as my unit will not act up again to confirm halt ages a sokenoid
  • Posted 24 Apr 2015 00:33
  • By josh_c
Thanks swoop223 ill check this
  • Posted 25 May 2012 21:49
  • By bert_m
I assume you mean F87?
this is the reverse transmission solenoid error code
there is a service bulletin out on this code
has to do with incorrect voltages to the solenoid
check the voltages
should be battery volts
-white wire B+
-yellow wire B+
-green wire B-
the coils should ohm out between 4-6ohms
this problem could be a bad solenoid
a bad F&R switch
bad wiring in the F&R circuit , ie: a broken wire or bad connection at a connector.
  • Posted 25 May 2012 11:29
  • Modified 25 May 2012 11:32 by poster
Maxlion MTF30-45-2WD
Taylor T520S
