coding out
I have a crown sc4500 that has a code 162.
  • Posted 12 May 2012 06:35
  • By 1sharpdog
  • joined 20 Apr'12 - 220 messages
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
Crownie,
I'm looking for a manaul on Access 123 can you help?
  • Posted 6 Jan 2014 08:12
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
Is there any way I can get a list of what all the fault codes are?
  • Posted 26 Sep 2013 03:13
  • By BulkUSA
  • joined 26 Sep'13 - 1 message
fault 111 is an access 3 comunication eror, check battery voltage to access 3 ca403-3 kys input
I have had a drive motor phase lead shorted to frame cause this code
fault 305 is high voltage on drive motor phase leads possibly blown fuse 1 or plugging issue
fault 323 is drive motor over temperature
  • Posted 5 Jul 2013 16:08
  • By crownie
  • Victoria, Australia
Crowny
Can you help me with the codes 323 305 and 111 please??
thank you
  • Posted 3 Jul 2013 12:05
  • By luis_y
  • joined 24 Oct'04 - 29 messages
  • Lima, Peru
All makes, the best service.
You are awesome, that's exactly what it was THANK YOU!!!
  • Posted 17 May 2012 04:47
  • By 1sharpdog
David Sharp
from memory F162 is weight sensor
  • Posted 16 May 2012 19:21
  • By crownie
Sue Tomic Sue Tomic
