massive help needed
I've brought in mechanics to check out the machine and they can't seem to find out this problem. Can anyone please help? When you drive to your next location and try to plug the machine backwards for it to stop, it doesn't work and vise versa backwards to forwards.
If your driving with it and make a turn or need to slow down and the throttle toggle goes back to neutral then you need to proceed again something doesn't engage to get the machine moving, but if you let it stand for 20 seconds or so, it then begins to move. Has anyone ever heard of this problem?
  • Posted 29 Mar 2012 11:26
  • By crazygrk
  • joined 29 Mar'12 - 5 messages
Original post deleted...
Forkliftaction does not condone the selling or trading of propriety information including authorization codes or any other dealing of copyrighted material by unauthorised persons. Any correspondence about illegal activities on our forums could put you in breach. Forkliftaction would be obligated to pass your contact details to police authorities if they were requested.
Please do not post these types of material on our forums again.
  • Posted 5 Apr 2012 05:01
  • Posted 5 Apr 2012 02:52
  • By crazygrk
grkmachine@hotmail.com
i finally figured out how to get my email on this thing. if you still have the wiring and troubleshooting info it would be much appreciated.
  • Posted 4 Apr 2012 12:12
  • By crazygrk
[email address removed]
  • Posted 30 Mar 2012 05:04
  • By crazygrk
If you list your e mail in your signature box I can send you wiring and troubleshooting info.
  • Posted 30 Mar 2012 03:11
  • Posted 30 Mar 2012 00:41
  • By crazygrk
Check all contact assemblies for proper movement. Make sure your tips are clean.
  • Posted 29 Mar 2012 22:27
  • By Prentice
1 - Make sure there is more than 100,000 ohms resistance from the frame to each of the power cables with the battery disconnected. If not, disconnect the drive motor and see if that is what has the ground.
2 - bad K2 plugging relay
3 - bad rec #1
4 - deteriorated scr # 1, 2, or 3
5 - control card problems
What kind of mechanics were these and how much did they charge?
  • Posted 29 Mar 2012 20:57
Briefs United States
