Hydraulic problem Linde H50D-394
Hi I have a problem on H50D 394 that is not easy. When we resease to descend the mast at the same time that we work with slow traction the descent is intermitent and if we press the stop pedal the mast descent well. At the same time other symptom is, if we let the machine on light inclination, free of brakes, the machine descend also intermitently and not continously.
We repaired the seal brake sistem and the problem is not solved, we will try to change the hidraulic block of hydraulic functions o fix the problem, have some idea what is hapening? Thanks
  • Posted 27 Mar 2012 21:10
  • By goncalosousa
  • joined 12 Sep'05 - 42 messages
  • Leiria, Portugal
Hello, Could you help me with service manual for LINDE H50D-394 series ? My e-mail is"[email address removed]"
Thank you so much.
  • Posted 27 Nov 2012 19:11
  • By consold_c
  • joined 20 Jan'10 - 29 messages
  • PRAHOVA, Romania
pracsis
Thank you michel, I have service manuals for linde forklifts, but the manuals does´nt explain all problems. Problem solved, discharge valve (15 bar) of transmition is stuck, and/or connectors of hydraulic pump valves exchanged.
Thanks for suport
  • Posted 29 Mar 2012 20:35
  • By goncalosousa
  • Leiria, Portugal
mail my for book
  • Posted 29 Mar 2012 03:44
  • By michel_v
  • noord holland, Netherlands
Problem solved, discharge valve (15 bar) of transmition is stuck, and/or connectors of hydrulic pump valves exchanged.
  • Posted 29 Mar 2012 03:13
  • By goncalosousa
  • Leiria, Portugal
Any solution? the main hydraulic pump is correct and valve block is also correct, there are a discharge valve on right side of pump with a spring, is the 15bar valve, is common a problem on that valve?
  • Posted 28 Mar 2012 22:40
  • By goncalosousa
  • Leiria, Portugal
Deborah Baker Deborah Baker
