CLARK TMG 20
I HAVE A CODE -51 TRYING TO DO THE TEST AS PER THE BOOK BUT UN ABLE TO FIND THE CAPACITOR FOR LINE CONTACTOR WHERE IS IT
  • Posted 29 Feb 2012 09:30
  • By MIKEM
  • joined 29 Feb'12 - 5 messages
code 51 only means the capacitor inside the controller has not yet charged up, and it is a normal code that flashes up for a few seconds on normal start up.
As per the manual, it can be the fuse or the controller, however I know that if you have to completely and correctly programmed the controllers, you will get that code when you replace the controllers. I also know that sometimes some loose connection into the controllers will cause this code.
  • Posted 1 May 2012 21:14
WHAT DOES CODE A51 MEAN I HAVE NOW CONTROLE OF ANY TYPE WITH KEY ON NO LINE CONTACTOR
  • Posted 1 May 2012 07:38
  • By MIKEM
yes, but there is a different cable, you may be getting the code 51 because it is not all set up to the trucks specs, (and which is master and which is slave), but you may also have some bad pins or plugs in the big connection.
  • Posted 1 May 2012 07:22
I HAVE INSTALLED BOTH NEW SLAVE AND MASTER AND WANT TO KNOW CAN I SET UP THE CONTROLERS WITH THE LX HAND SET
  • Posted 1 May 2012 07:15
  • By MIKEM
You may be able to swap the controllers. You will ahve to configure them as master and slave. I think that the master contoller controlles the line contactor. It is a possibilty that the controller is just bad.
  • Posted 1 Mar 2012 09:51
  • By rogeriwt
BOTH CONTROLERS WERE REBUILT AND EVERSINCE THE REINSTALL THE CODE -51 HASE BEEN THERE THE WIRE HARNESS CHECKS GOOD BATTERY VOLTS ARE TO SPEC DO YOU THINK ANY OTHER THING COULD CAUSE THIS OR IS IT TIME TO BUY NEW OR USED CONTROLERS
  • Posted 1 Mar 2012 02:13
  • By MIKEM
The Capacitors are internal to the control module
  • Posted 29 Feb 2012 10:04
  • Modified 29 Feb 2012 10:06 by poster
  • By kevin_t
October 8-9, 2025 - Twickenham, United Kingdom
Mike Barker Mike Barker
President and CEO Swisslog Americas, Swisslog
Vice president, Newgentech Material Handling India
Sales representative, Alabama and Panama City, Thompson Lift Truck
Chief marketing officer, Bobcat Company
edition #1239 - 17 July 2025
As part of Forkliftaction’s 25th anniversary celebrations, we have dug into the archive and, over the next year, will be highlighting a carefully curated selection of historical stories we have published over this time... Continue reading
