Code I07
can someone tell me what this code petains to. Unit will not move just beeps
  • Posted 26 Jan 2012 10:08
  • By jerry_c
  • joined 5 Oct'10 - 26 messages
You are in active maintenance mode. This is not a trouble code. It's an input parameter that you can command on while the truck drives normally. Someone selected this feature and turned it on either by accident or for testing the reach "out" switch on the control handle. If you depress the retract button you should see i 07"in" if the display does not change then you have a bad vehicle manager. That may be why the "Input 07" is on the display. If the truck is running fine just leave it. If it reaches in and out then the switch is ok. you can try to clear the test in active maint. Do you have the superword to access the maint mode?
  • Posted 2 Feb 2012 21:22
  • Modified 3 Feb 2012 07:28 by poster
  • By EasiTek
the unit is an easi reach truck. the code that comes up is i07 out.
  • Posted 1 Feb 2012 03:12
  • By jerry_c
I'm sorry, is that i 07 or 107 (one o seven)
And what model. EZ A, EZ C? You may be showing "Input 07"
As there is no code 107 on a reach......
  • Posted 31 Jan 2012 12:19
  • By EasiTek
Thank You Ray. Our code that comes up is I07. Is that the same as e107?
  • Posted 31 Jan 2012 10:10
  • By jerry_c
There is many posts further back on E107. #1 cause is dirty contactor tips. #2 cause is Main fuse burned from overloading. Check main fuse, if ok replace tips. Cleaning them works somtimes
  • Posted 29 Jan 2012 23:43
  • By EasiTek
Enforcer FD50T-MMA
Morooka MFD20
Atlanta Savannah Orlando Tampa Jacksonville West Palm, United States
St. Louis, MO, United States
Ottumwa, IA, United States
The black box flight recorder was invented by Australian scientist David Warren in the mid-1950s. While initially met with indifference in Australia, his invention gained international recognition, particularly in the UK, and is now a mandatory piece of safety equipment on all commercial aircraft.
Zhejiang UN Forklift Co., Ltd
Enforcer FD50T-MMA
Morooka MFD20
Dwight Klappich Dwight Klappich
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Executive director, NT WorkSafe
Chief executive, Logistics UK
