No Travel
Have no directional travel, no pot voltage from access 3 using meter, analyzer shows travel switches working and no pot volts, access 3 was replaced by customer and has same problem again, was told motor encoder could cause access issue, but how can you check encoder when motor doesn't turn
  • Posted 22 Jan 2012 11:46
  • By dhls
  • joined 20 Jan'12 - 10 messages
Any encoder on any lift truck or Automobile can be checked without power. These produce A/C voltage. Just unplug and test 2 terminals while spinning the motor by hand. They produce.8 to 3 volts A/C, depending on how fast you spin them. Your ABS wheel speed sensor on an automobile is the same.
  • Posted 26 Apr 2012 08:45
  • By EasiTek
hey i had a couple snapped wires in the base of the handle just onder the springs where the handle pivots. i had no pot voltage either i replaced pot and the whole upper handle harness and still had nothing until i accidentally saw the wires broken in the base of the handle when i was checking voltage on control board. once i replaced the lower harness that plugs into the scr control board everything was fine no calibration was needed.
  • Posted 25 Apr 2012 07:04
  • By 3wsdace
  • joined 4 Dec'11 - 4 messages
  • Illinois, United States
Hey dhls, If you have no potentiometer counts through the analyser menu, i would check that the potentiometer, and connections are good. If they are I would suspect that you have broken wires in the handle harness. This is a very common problem and occurs often. I have seen broken wires in the cable as low as 250 hours of operation. Jack the machine off the ground and ohm out the 3 pot wires 1 by 1 from one end of the harness to the other and move the handle around as you do. If another harness is available you can connect it without actually installing it throught the handle to varifiy that the harness is actually the problem.
  • Posted 27 Jan 2012 17:32
  • By Mack
  • joined 25 Feb'10 - 2 messages
  • British Columbia, Canada
check the little 15a ceramic fuse
  • Posted 22 Jan 2012 18:10
  • By crownie
  • Victoria, Australia
Briefs United States
SMV (Konecranes) SL37-1200A
Terberg YT222
Terberg YT222
