Do you have any Liftking questions?
Feel free to ask me any questions about our products (Liftking, Noble, Lowry, Schaeff, Ferrari CVS) or about our company.
I've worked here for many years so chances are I can help you out.
If you have any questions about our other Manitex brands (Manitex boom trucks, Badger rough terrain cranes, Loadking tailers) I'd be pleased to pass your enquiry along.
Thanks!
Guido
  • Posted 6 Jan 2012 07:46
  • By Liftking
  • joined 6 Jan'12 - 14 messages
Hello,
I am working on a Lift King LK-20M42.
It had no throttle at all. Machine runs great, but no throttle. I hook up my laptop to EST so I can talk to the Perkins engine it has. On EST I am seeing the engine is reading we have throttle. The throttle position on EST goes from 0-100%.
No ACTIVE codes, but it does have a bunch of LOGGED codes on it.
Anything helps!
Thanks!
  • Posted 8 Jul 2025 03:55
  • By BigFieldTech
  • joined 8 Jul'25 - 1 message
  • MN, United States
Hello not sure if i am doing this wright. But i have a Question. What Hydraulic oil goes in a liftking LK-6M42 forklift can not find in my book that i have
  • Posted 22 Sep 2014 23:53
  • By Dave2013
  • joined 10 Jan'13 - 20 messages
  • Oklahoma, United States
Liftking,
Appreciate your help! Performed all diagnostics and calibrations, as suggested. Found a hydraulics leaking on the backside of the left traction motor. Repaired it. Also, encoder was having too much chatter, causing communication problem.
Advised my supervisor, we would need encoder, belt, and gears.
They put it on the back burner. Just wanted to let you know, you where a great help. I will keep you updated, if they would allow me to repair this unit.
  • Posted 25 Aug 2012 06:48
  • By 269Chalmer
  • joined 14 Aug'12 - 10 messages
  • Michigan, United States
Hey liftking! Sorry I didn't get back to you any sooner, had other jobs come up.
PROBLEM: Lots of coasting, with little deacceleration?
I checked over the steer motor, it appears to be fine. The joystick is tight and the spring return is good. I checked over the electrical wiring, and found no issues. I also, checked all the cable pin connectors and cleaned them, then re-connected them.
Thanks for the general password. I calibrated the steer and lift, I don't get how to calibrate the traction motors?
I checked the setting at the COAST/DEC, its set in the middle.
I checked recent history "fault codes", and came up with a consistent mix of codes: 68L, 66R, 66L,68L,51L, and etc.
Working on this, is kinda tough without a service book or support. So, appreciate your help.
I'll email you
  • Posted 21 Aug 2012 11:07
  • By 269Chalmer
The speed automatically slows down as the truck turns. The speed reduction varies with the angle of the turn, getting quite slow in a tight turn.
The steer motor should have no play. If the motor is moving at all, the technician needs to dismantle the system and find the loose bolts, etc. This looseness can cause some of the symptoms described.
The technician should examine the control handle for looseness and mechanical play as it should be "tight". (The handle should have a firm neutral position, if it will flop even a small distance, the system will have trouble putting the motors in neutral and they may hum.) Also look for lose or bare wire wires of frayed insulation and cabling. Intermittent connections will give various problems.
The general password is "HLP", although someone may have changed it.
The technician needs to go through the general steer pot and lift and travel pot calibrations. (If he can get into diagnostics.)
Please tell me the specific error numbers so I can help.
Please take care of the mechanical looseness and possible wiring problems before trying to fix any of the other symptoms as those problems may cause the symptoms. Chasing the symptoms without fixing obvious problems is not productive.
Please send an email as per above post or provide your phone number if you'd like us to contact you directly.
Thanks.
  • Posted 17 Aug 2012 03:20
  • By Liftking
I'll get the answers for you. In the meantime shoot me an email with your tel # as it may be easier to discuss the details over the phone.
Email: guido AT liftking.com (AT = @)
Thanks!
  • Posted 17 Aug 2012 00:32
  • By Liftking
Ghost Issue with Travel and Deaceleration!!!!
Thanks for the info! I do have other questions on the unit? I've been getting sporadic error codes, like Left traction error, right traction error, and steering error. Cycle power at the key, error goes away, but after awhile a code will reappear.
I notice when travel forward or reverse, I release the joystick, the traction motors(left or right) is humming, then goes into a error code. Almost like the joystick is not going into neutral.
It also goes into a slow travel mode, when turning left or right.
Also, it coast in either direction for about 6to8 feet before the traction motors begin to energize with the joystick (Stopping Perposes).
I also look down at the steer electric motor, it seems to be move about an 1/2", side to side, when turning the tiller. Don't know what type of play it should have?
I'm thinking steer pot at the tiller? But the steer pot cable is link to the lift amp.
I dont have access to diagnostics...its password protected.
I hope this make sense, with the problem I'm having.
Appreciated
  • Posted 16 Aug 2012 08:42
  • By 269Chalmer
The COAST/DEC setting in the menu will control the response of the motor speed to the control handle position. There is "HARD" to "SOFT" settings and "OFF". "HARD" will give a snappy throttle with fast acceleration and deceleration, "SOFT" gives slower smoother response. With "OFF" there is no deceleration, the truck coasts to a slower speed rather than power deceleration and "RAMP HOLD" is inactive. The system will give a warning at truck start up if COAST/DEC is OFF.
If COAST/DEC is not OFF the truck will begin to plug to the lower speed. Plugging will be more severe if the joystick is moved to the opposite direction. The control system always tries to set the speed to the handle position, so if you move the handle to a different speed, the system sets the motor power to that speed.
  • Posted 16 Aug 2012 01:31
  • By Liftking
Schaeff W Series.. If you have your foot on the dead man brake pedal and proceed forward traveling at top speed, then release the joystick to a neutral position. Would the unit start plugging to a lower speed? Or does plugging start when the joystick goes in the opposite direction?
  • Posted 15 Aug 2012 10:44
  • By 269Chalmer
Hi Roma,
Compared in what respects?
Send me an email so I can send you more information and attachments:
guidoATliftking.com (AT = @)
Thanks!
  • Posted 9 Mar 2012 03:17
  • By Liftking
How is SCHAEFF forklifts ? compared to lager brands and manufactures ?
  • Posted 8 Mar 2012 03:41
  • By roma_f
  • joined 20 Sep'11 - 31 messages
  • doha, Qatar
ADVANCED LIFT TRUCK SERVICE GERALD.
  • Posted 8 Jan 2012 09:00
  • By towmotor
  • joined 19 Feb'07 - 360 messages
Absolutely. Who can I say is sending them?
  • Posted 6 Jan 2012 23:55
  • By Liftking
give regards to tom antonio
  • Posted 6 Jan 2012 10:39
  • By towmotor
Muncie, IN, United States
Linde Material Handling
