precharge fault code 33 on PE4000 pallet jack
im thinking iot the controler used hanset every function work except line contactor doesnt pull in its got power to contactor.. i replaced coil..and same.. anybuddy seen this????
  • Posted 3 Dec 2011 04:55
  • By irrk1
  • joined 5 May'11 - 24 messages
If the pump solenoid is stuck. It will cause the line contactor to drop out after key on. Tap the solenoid.
  • Posted 8 Jan 2014 08:10
  • By Tiki
  • joined 8 Jan'14 - 2 messages
the Controler was bad...
  • Posted 4 Jan 2014 10:12
  • By irrk1
Is the pre-charge resistor getting "HOT",when the battery is plugged in? If so,check the pump motor solenoid,and make sure it's not stuck closed.
  • Posted 14 Dec 2011 14:45
  • By Truck_Tech
  • United States
GemOne
Michel Denis Michel Denis
