Fault code 243
Hi,
Does anybody can let me know what is the fault code 243 on clark TMX20?
  • Posted 18 Oct 2011 02:05
  • By Jose
  • joined 24 Oct'09 - 7 messages
  • Sonora, Mexico
thank you 255 is sorted and also 84 the adjustment worked. Do you think you could help me with atlet, UNS 200 error E97.
  • Posted 8 Jan 2012 17:39
  • By raphael_d
  • joined 16 Oct'10 - 6 messages
  • Ajman, United Arab Emirates
255 is the parking brake switch. 84 is the steer sensor is out of range. The pb switch could be just the switch out of adjustment, that is what it usually is. The 84 you need a handheld to check what the controller is seeing from it.
  • Posted 6 Jan 2012 13:10
  • By rogeriwt
what about fault code 255 and 84? can anybody help with this
  • Posted 5 Jan 2012 16:35
  • By raphael_d
The master controller has lost communication with the pump controller. It could be a harness issue or the controller in ng. I would check the harness, those controllers are expensive.
  • Posted 21 Oct 2011 11:55
  • By rogeriwt
