Pedestrian safety around lift trucks
Recently we have had a flood of accidents involving people not looking for lift trucks before they enter an aisle and getting hit. (Prior to this, we have not had an accident like this in 10 years plus.)
Background information: Our lift trucks are electric (very quiet) and in some areas it is very noisy due to our metal stamping operation.
We are now looking at devices like strobes, beepers, backup alarms, etc. to alert employees The remark is that employees will get immune to these devices or they will drive the material handlers "crazy" listening to the beepers all day.
What do you suggest?
  • Posted 24 Aug 2004 22:45
  • By doug_b
  • joined 24 Aug'04 - 4 messages
Doug B
Showing items 1 - 20 of 25 results.
Doug, have you found a solution yet? Have a look at EV Alert.com.au.
  • Posted 20 May 2005 11:11
  • By donna_b
  • joined 20 May'05 - 2 messages
  • Victoria, Australia
At EV Alert we help you work safer & smarter.
There's something new in Australia that is unique in that is is not infra-red, so it DOES see around corners. The EV Alert coded UHF signal (adjustable from 0-40mtrs(0-130ft)) activates any device, receiver on wall, speed delimiters, it opens doors, sirens, flashing lights. In addition you can include a personal pager unit that buzzes & vibrates. The VHF unit has a range of 0-500mtrs) Has applications for trucks, trains, forklifts, you name it. evalert.com.au
  • Posted 20 May 2005 11:06
  • By donna_b
Garry
Thanks for your reply.
I ahve sent a message to Wayne and will let you know how I get on
Regards
Jim
  • Posted 11 Mar 2005 19:51
  • By jim_h
  • joined 3 Mar'05 - 5 messages
Doug for some reason my e mail message can not be shown so you could try leaving a text message on my phone on 07739 774999 plus whatever code you need to get to the UK. I am busy at the Glassex Exhibition with this truck at the NEC in Birmingham UK 13th to 16th March so it is probably the best way.
Regards
Jim
  • Posted 11 Mar 2005 19:32
  • By jim_h
Doug; You may have difficulty changing the attititude of the pedestrian or the fork truck driver, part of being human I suppose and it is too late to tell them if and when there is an accident. There is another approach to consider though. Depending on the application, you could consider putting the driver onto a Pedestrian truck It would slow him down (hopefully not your operation though) and make the environment safer for everone (no emissions) plus such a truck can be much more cost effective. My company Hubtex has just launched a new truck on the market, a 4 Way Pedestrian truck which solves many problems handling awkward sized loads indoors plus normal pallets. As I do not wish to use this space for free advertising, please contact me direct on [email address removed] if you would like more information
Regards
Jim
  • Posted 11 Mar 2005 19:28
  • By jim_h
Jim:
To respond - if it's permitted. The person you could contact is Wayne Borean of Nett Technologies.
Wayne can provide some unique information as he's now with exhaust specialists and prior, he was with a lift truck dealership and has "much" insight on electrics, propane and diesel.
Their website is www.nett.ca, phone 1-800-361-NETT or 1-905-602-7747 ext 103.
E-mail [email address removed]
Let me know how you make out, please.
  • Posted 11 Mar 2005 10:43
  • By garry_p
  • joined 4 Nov'04 - 27 messages
  • New Brunswick, Canada
Doug It sounds like you have a big problem!
You need a good risk assessment done, The soloution will become evident
Here is how - (A) Spot the hazard - clearly identify the problem.
(B) Assess the risk - Obviously it is an intollerable one.
(C) Fix it
(D) Early A.S.A.P.
This is the "S.A.F.E." system.
Do this by Eliminating the problem,Substitution, Engineered controls, Signage, Provide personal protective equipment & train your operators and your pedestrians.
For a company to suffer the described occurances you must have the pedestrian and forklifts working in the same area at the same time, If you can not separate them then you must train them to co-exist through policy/ proceedures & training.
Human life is the most important thing to be conciderd here.
Ask yourself "Is your company placing unreal expectations onto your drivers (this could be unstated but real none the less).
Priority should be given to creating a 3 meter exclusion zone around each forklift ( a no go zone).
I tend to think that too much speed is also involved here and also.
Priority shoul also be given to ensureing management awareness of the situation,
because management is responsible for the situation & soloution.
You must act immediatly and do not be hesitant to call a spade - a spade - state it as it is & where it needs to be said.
Don't forget to go back and to write down the common factors in all your incidents, this will point to the root cause or causes (a combination of factors).
Good Luck.
Dangerous.
  • Posted 11 Mar 2005 07:13
  • By DANGEROUS
  • joined 6 Feb'05 - 17 messages
  • Queensland, Australia
"OUR BUSINESS IS SAFETY"
Garry Thank you for your prompt repy. Away from the article I am looking to produce, my quest is to get more information that will assist me to convince some customers to consider the better long term option of running electric trucks indoors. I would like to communicate with your contact in Canada as I feel this could be very useful. Thanks again for your assistance and I hope to hear from you soon.
Regards Jim Hammond
  • Posted 3 Mar 2005 21:37
  • By jim_h
Jim:
Diesel trucks are not just for outside anymore. If you've been looking at the UK, I think you will find diesel trucks are used in many applications - inside. Their exhaust emissions can be controlled to make this possible.
Propane units are still popular, but as with all fuel types, carbon monoxide can be a problem if not monitored.
Electrics - over the years are gaining in popularity especially where they are working around food products and close proximity to pedestrian employees.
The cost is more expensive, but when you figure out that you're buying your fuel for the next 5 - 7 years in the initial price then the price becomes more realistic. Coupled with the comparison of a per hour rate for maintenance.
Electrics can come with pneumatic tires and can be used outside, but the capacity has been the problem that causes Companies to look at propane/gas or diesel.
You may also see a difference in cushion tire trucks used in North America and not as popular in the UK.
There are many Companies that sell exhaust purifiers for Diesel units and I'd recommend you speak to some of these people. I can supply an e-mail address for a gentleman in Canada that is very knowledgeable on this subject and could perhaps give you some very accurate information.
Regards
Garry Prosser
  • Posted 3 Mar 2005 21:03
  • By garry_p
Dear Industry Colleagues
I am currently compiling information to produce an article in a magazine
which explains the best suitability for fork trucks in different areas.
Common sense tells most fork truck dealers offering trucks and customers
that the following applies;
DIESEL TRUCKS; OUTDOOR USE MAINLY WITH RESTRICTED USE INDOORS
LPG TRUCKS INDOOR AND OUTDOOR USE WITH LITTLE RESTRICTION
ELECTRIC TRUCKS; MAINLY INDOOR USE WITH OUTDOOR USE IF THE DESIGN OF THE
TRUCK PERMITS IT.
My problem however is this. My competitors sometimes tell my potential
customers that their diesel trucks will work indoors more frequently than
the above statement suggests and have also said that LPG trucks can work
indoors all the time without harm to employees. They say this because they
do not have an electric truck in their range.
I represent a manufacturer of Diesel, LPG and electric trucks and as such, we
can be seen to be acting impartial in any application. My concern is that
the information I have on the suitability of differing trucks in various
applications is limited and have tried to seek information from differing
sources without success.
It seems at the moment that there are potentially many thousands of
employees who are exposed to the harmful emissions from fork trucks working
indoors and this situation is going unchecked only because of ignorance
towards legislation, which includes myself.
I have already asked the HSE in the UK for information on this subject and have received a reply but it still does not give very clear guidelines. It seems only after a truck has been installed can suitability be properly tested, be that time it is too late and the wrong investment could have been made.
My own thoughts are that it has to be the combination of emissions, airspace
and ventilation that should determine what is a safe or unsafe environment.
This study could have wide ranging implications for my prospects and
customers alike and I would really like to help and educate these people to
help them to give their workforce a better, safer place to work in. It will
also benefit many people/companies who will never be customers of mine and I
also wish to help this much larger sector.
Can anyone offer additional advcie please?
Regards
Jim Hammond
  • Posted 3 Mar 2005 20:46
  • By jim_h
Brian,
You assume correctly. In adddition, it is a sit down truck and is quite large.
Doug
  • Posted 26 Feb 2005 04:11
  • By doug_b
Doug,
Forward I will assume means "forks leading" or "forks first". Sit-down Rider Truck or Stand-up Rider? How big is the truck (capacity)? Just wondering.
Brian
  • Posted 25 Feb 2005 09:21
  • By brian_c
  • joined 10 Dec'04 - 5 messages
Hey Doug, sorry to hear of your misfortunes in the workplace with the forklift accidents. There is a product available that has been tested to decrease this exact problem. To view all their products go to alertsafetyproductscom....check out their action videos to actually see how the products works. You can call 8007834290 for further assistance
  • Posted 19 Feb 2005 04:41
  • Modified 19 Feb 2005 04:45 by poster
  • By bill_chernick
  • joined 19 Feb'05 - 1 message
Brian,
Interesting thinking!
To answer your question, the empty lift truck was going forward
  • Posted 19 Feb 2005 04:20
  • By doug_b
Procedures, procedures, procedures!! You need clearly defined written procedures acounting for all interested parties.
Operator procedures, do's and don'ts, including horn use, visibility/obstructions, blind spots, verifying clear travel, travel speed, slowing down, stopping as required.
Pedestrian procedures, dedicated walkways, restricted areas, hazards of lift truck traffic. Train everybody on procedures. Enforce, enforce, enforce!!
Lights and alarms may be more than a nuisance. They may create another hazard if improperly applied. I detest "back-up" alarms on forklifts. Dump truck, ok, forklift, not! They beep in the wrong direction. If you add a travel alarm, have it beep in the "forks first" direction, which is the direction with obstructed view, and it will encourage travel in "forks following" direction, which provides the best view. Which direction was operator traveling when pedestrian was struck? Loaded or empty?
Establish dedicated pedestrian walkways, and restrict pedestrian traffic in areas where they have no business. When a forklift operator has to stop for a pedestrian, workflow and procuctivity is obstructed, affecting bottom line numbers. Don't want that, do you? Concave mirrors are very effective when all employees are trained, and required to use them. Remember, if you require it, you must enforce it, or it's not required.
  • Posted 18 Feb 2005 00:33
  • By brian_c
Nothing is idiot-proof to a motivated idiot.
In view of the high ambient noise levels and general nuisance of permanently on bleepers, the preference should be for fixed wall mirrors, strobe lights and lane markings.
All are reliable and inexpensive.
"Clever" ideas fail when the equipment fails and production must go on!!
  • Posted 11 Feb 2005 02:56
  • By rod_s
  • joined 31 Jan'05 - 9 messages
  • England, United Kingdom
Doug,
Advanced technology may be your answer. These new products can deliver warnings only when really needed. Check them out- ForkAlert. A link is triple w dot ray-safe.com Hope this is helpful.
  • Posted 5 Nov 2004 03:17
  • By Joanne_a
  • joined 30 Sep'04 - 1 message
www.RAY-Safe.com
Doug
Your original question opens a very large door.
First, pedestrian employees in order to be "competent" must be made aware of the dangers to their health & safety connected with the assigned work. This should be part of their orientation package - their do's and don't's working around lift trucks. This comprises many different topics. If you'd like to contact me off-line ([email address removed]), I'd be pleased to fax you a copy of my 2 page Pedestrian Safety Manual that I pass out when I do my courses.
Second, at all blind corners, doorways, inter-sections, any place there could be a collison between a lift truck and another object or person, there must be an overhead mirror.
Back up alarms are a requirement in some Provinces/State, but even so: all lift trucks should have a flashing light that is mounted to the top of the driver's overhead guard and be flashing at all times - come on with the key.
Also, headlights and a back up light are mandatory when used after dark or in dimly lit areas, but my recommendation is 2 headlights that come on with the key, "daytime running lights" and the reverse light should come on when the unit is put in reverse - not by a separate swith.
Pedestrians can see the reflection of a light in an overhead mirror before they see the reflection of a lift truck. Also, at blind corners, inter-sections and doorways, a light may be seen shining off walls/boxes/racks even before a lift truck can be seen.
Lift truck operators must be told that at all blind corners, doorways, inter-sections and when they make a turn that: they must slow down to a yield speed, sound their horn and yield right-of-way.
Back up alarms must be audible over any background noise. The loudest I've seen is 120Db. In a noisy application, make sure you have the loudest back up alarm available and it's located for maximum sound (not under an engine or battery hood as example).
For forward travel, you can purchase a bell alarm that attaches to the wheel assembly. Each revolution creates a bell - the faster the lift truck is going, the more "bells" that go off.
Pedestrian safety garments: lift truck drivers that hit a pedestrian usually say, "I didn't see him or, I didn't see him in time." Consider safety garments, i.e. vests or something else. There is a relatively new standard in the U.S. and one in Canada as well with different classifications for different applications.
Pedestrian sidewalks painted on the floor keep pedestrians in a certain area and not all over. Drivers stay off the "sidewalks" and.....some Companies paint 2 lines on the floor to designate a lift truck highway so, all said and done, you have a separate area for lift trucks and pedestrians to eliminate or reduce collisions.
Yield or Stop Lines painted on the floor can also remind lift trucks and pedestrians to yield at a blind area.
These are just a few of the ideas to respond to your inquiry. Hope they may help.
Regards
Garry Prosser
  • Posted 4 Nov 2004 20:14
  • By garry_p
Hi Doug
The Department of Labour in their Occupational Safety General Regulations, for the province of Nova Scotia, Canada requires lift trucks to have "an audible back up alarm or equivilant safety device" inatalled. You may want to consult your local regulations. When teaching driver training classes I stress to all students the importance of watcing for pedestrians and encourage managers and employers to do safety audits and stress pedestrian safety courses.
It is worth the cost of having a competent professional consultant spend time at your facility in conjunction with your health and safety committee assesing oportunities for improved lift truck safety.
  • Posted 12 Sep 2004 11:47
  • By randal_s
  • joined 12 Sep'04 - 36 messages
  • Nova Scotia, Canada
doug - i think you hit the nail on the head when you stated people have stopped looking out for f/lifts - I agree that yes the opertaor MUST sound the horn- however as you stated in your own work place - not all sounds can be heard!
Perhaps the staff may need to be reminded before its not too late as to the danger's of Flifts and remind them that they too need to look out for their own safety also - after all the operator can only do so much! (Sound horn/ slow down)
A team effort is needed on both operator and pedestrian - Mirrors etc are fine - as long as pedestrians remember to use / look at them!
  • Posted 10 Sep 2004 18:27
  • By paul_s
  • joined 10 Sep'04 - 3 messages
  • wellington, New Zealand
Komatsu FD25T17
UN Forklift FD35T-C2JB2
Komatsu FD25T17
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
