Linde experts? T20SP error 401
Hi there,
My costumer has three T20SP/131 trucks. Two of them intermittently have error code 401. (Internal error: Torque too high according to setting). But of course not when i'm there. When I read the error code list it appears that this error occurs a couple of times within a short period, and the stays away a couple of hours/days.
any hints?
  • Posted 30 Aug 2011 06:55
  • By frits_f
  • joined 19 Dec'09 - 320 messages
  • utrechte, Netherlands
Hi MEngr,
Thanks for your reply. It is not completely clear to me, but if I understand it right I have to give the cornering speed, the steering angle and the hysteresis a higher value. I will try that.
Can you tell me the relationship between the phase voltage and the cornering speed? In other words,how can the cornering speed reduction cause this error?
regards.
  • Posted 31 Aug 2011 18:07
  • By frits_f
frits;
The Standup Pallet you are dealing with has an issue of "Torque set point to high as viewed by the two processors".
The measured phase voltage does not match the nominal voltage, and the traction deactivates. The values are misadjusted in the Linde AC window for 'speed reduction while cornering". Should your customer should insist on a higher steering angle before speed reduction is activated, the hysteresis and cornering speed should also be set to max in addition to steering angle. This should stop this error from occurring again.
  • Posted 30 Aug 2011 23:28
  • By MEngr
  • Missouri, United States
Maxlion R2D25
Taylor T650L
