Vaporizer blowing raw fuel
Having a problem with fuel going right thru the Nikki vaporizer. When I pull the fuel inlet hose at the carb, it has way too much pressure and blows raw fuel. Anyone else have this problem? How do I fix this? Thanks, Jim
  • Posted 26 Jul 2011 09:13
  • By jim_v
  • joined 26 Aug'08 - 61 messages
  • Michigan, United States
You need to clean and rebuilt it, it will work properly.
  • Posted 28 Dec 2018 16:37
  • By olivia_g
  • joined 28 Dec'18 - 2 messages
  • United States
I know this post is goes back a few months but i would like to comment a little on this system and parts cleanliness. As most know, the lpg regulator on these trucks do not operate like the systems found in earlier Nissans equipped with model J Impco regulators. Unlike the older trucks, these are not dependent on direct vacuum from mixer as these are without. These have constant fuel vapor pressure to injector holder. The injector holder has 2 ports which feeds into the throttle bore. Also said holder has internal relief valve that will purge or dump excess pressure from injector holder into throttle bore via a small port which is located 90 degrees clockwise from main injector port. This is to relieve pressure from the flexible fuel supply hose from regulator to injector holder due to heat and gas expansion. Even with engine not running, dumping will continue to occur until pressure is no longer enough to open dump valve. This replaces the "weeping" hose as found on the older models. It is very important to drain tar from these regulators. I occasionally remove the lpg assist injector from time to time and inspect or clean as these can on occasion get gummed up if improper fuel other than whats recommended is used or the vaporizor is not drained as required. When replacing any component mounted on or including injector holder or ETC, i take great pains to make sure components are free of any dirt, dust, rodents or their nests. With a contaminated injector holder any debris can cause sticking main injector or damage, damage to lpg assist injector or its seating or worse a possibility of preventing purge valve not to seat or stick when dumping. After all it does have a final chance screen located in the injector holder itself and isn't there for looks. There is also filter mounted in lock-off assy. The purge valve being internal to injector holder itself is not accessible. I rather take a few more minutes and make sure regulator is drained every 200 hrs and replacement injector holder parts are squeaky clean when replacing or removing for diagnosis. Sure saves time and trouble down the road. Just my few cents worth.
  • Posted 12 Nov 2011 18:51
  • Modified 13 Nov 2011 03:58 by poster
  • By RCAV8TOR
  • Alabama, United States
the small valve on front
  • Posted 5 Oct 2011 10:45
  • By jim_v
I am having same problems, with no books. What is the boost valve?
  • Posted 5 Oct 2011 09:16
  • By indiana_ed
  • joined 5 Oct'11 - 1 message
  • Indiana, United States
Had 5 psi at regulator. Found boost valve gummed up. Just cleaned it with parts cleaner and reinstalled. Presto, it fired up. Thanks for your help.
  • Posted 27 Jul 2011 06:54
  • By jim_v
Jim;
Install a pressure guage in the 1/8 BSP tap port of the regulator with the coolant at operating temperature and see that the pressure holds at 4.6 - 4.8 psig for 1 min. While this is being done also, see what the PC says the pressure is. You may have one of the two reliefs in the throttle body gummed up and not sealing.
  • Posted 26 Jul 2011 23:21
  • By MEngr
  • Missouri, United States
I have drained it every PM. I replaced the vaporizer and still have the same problem. Any other suggestions?
  • Posted 26 Jul 2011 20:39
  • By jim_v
Jim;
You have a truck which hasn't been maintained per mfg. spec..
The solution is to replace the vaporizer - regulator at approx. + 800.00 USD or take it to an authorized dealer to have it cleaned and rebuilt for a third of that. Once this is done and the regulator is reinstalled and readjusted. The engine will need to be relearned. At 200 hour intervals the tar drainning is required.
  • Posted 26 Jul 2011 15:33
  • By MEngr
Unicarriers FD80-2
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Esie Cortez Esie Cortez
Unicarriers FD80-2
USD1
