WON'T START -DASH SAYS "TURN KEY OFF"
I'm a bit confused on this one everytime I turn the key on the dash displays "turn key off". Line contactor doesn't pull in or anything. Will the LX handset work on these controllers to check for faults?
  • Posted 4 Feb 2011 11:25
  • By troy_m
Hi , I just have the same problem today. Did you remember what was the problem ?
  • Posted 14 Sep 2017 09:59
  • By tech1986_t
  • joined 24 Oct'13 - 2 messages
  • Quebec, Canada
Tech
  • By tech1986_t
  • Quebec, Canada
Tech
So it turns out the seat switch was open. FYI
  • Posted 5 Feb 2011 08:49
  • By troy_m
Libiao Robotics
