Stall test procedures
hello all,
i have a Hyster H80XL serial G005D02562P this truck is very sluggish and has a hard time pulling a ramp. i am suspecting that we have a torque converter problem.
could anyone e-mail me the stall test procedures on this truck?
e-mail address
bcline at umsinc dot net
thanks in advance
  • Posted 8 Jan 2011 08:50
  • By bruce_c
  • joined 28 Jul'10 - 52 messages
  • Missouri, United States
I think john missed the "not" and a zero. as in "if the engine is near top rated speed of 2200 rpm and the wheels are NOT spinning, then you have a problem with the torque converter, and in truth, if your converter is broken, it is more likely that your engine will not be able to get to it's max rated speed while in gear
  • Posted 19 Jan 2011 21:35
Thank you all for your help.
  • Posted 19 Jan 2011 11:00
  • By bruce_c
The torque converter should reach stall at approximately the max. torque rating speed (rpm) of the engine. That should be some where around 1500-1600 rpm. If the engine speed is above that and close to the governed speed of 220 rpm (as Ed T stated) and the wheels are spinning then you have an issue in the converter.
  • Posted 19 Jan 2011 10:39
  • By johnr_j
"Have An Exceptional Day!"
3 or 4 thousand RPMs on a 4.3 GM v6 in a forklift?
my book says 2200 is top RPM when properly governed...
  • Posted 19 Jan 2011 09:12
Simple, pull it up against a solid wall or loading dock, put the carriage up against the wall or dock. Put it in forward slowly press the throttle to the floor, if the tires spin your converter is locking, if your getting 3 to 4 thousand rpms at the engine and the wheels arent spinning the converter is shot.
  • Posted 19 Jan 2011 03:29
  • By bigGlittlestar
  • joined 12 Aug'08 - 139 messages
  • United States
