Fiat om EU13 / 17.1
Hello friends
gave me a hot potato. fiat om "EU3 / 17-5, OM 17-5 dismantled and would like to know the connection of the engines because they do not know. marellimotor has two engines that were a bit worse. have for the engine up two thin wires one blue and one beige. low for the engine has two thin wires a black and yellow. These cables connect to the terminals small engines. if I can help, thank you.
Ouvir
Ler foneticamente
  • Posted 14 Sep 2010 09:12
  • Modified 13 Oct 2010 08:57 by poster
  • By AMartins
  • joined 8 May'10 - 107 messages
  • vila nova de gaia, Portugal
No problem electrodrive.
Regards Shane
  • Posted 15 Oct 2010 04:30
  • By controlelectric
  • joined 8 Dec'08 - 70 messages
  • Shropshire, United Kingdom
It takes years to build up trust, and only seconds to destroy it. controlelectrics.uk@gmail.com
Hello Shane
Any can u send me a cop of the info please :)
  • Posted 14 Oct 2010 18:08
  • By elektrodrive
hello guys
've got to work. after repair of traction motors and the links were all thanks to your help, which only began operating in acceleration to the left slowed down and sobbed, I again clean and everything was more or less. ok. but... appeared (FW "32C # 3), when I unplug the machine appears (Tens. OFF) lights red light on top and the wheel does not work with anything I unplug the plug from the battery 2 or 4 times and start working. this is not always.
thanks
  • Posted 13 Oct 2010 08:50
  • By AMartins
hello guys
very grateful for the information.
thanks to you, I'll do a good job
a hug. A. Martins.
  • Posted 16 Sep 2010 08:30
  • By AMartins
Hi, AMartins, below wire-colours from schematic:
Left-motor:
FIELD1 red, FIELD2 black, brush-check 2 wires black-blue, FAN- black, FAN+ red.
Right-motor:
FIELD1 white, FIELD2 blue, brush-check 2 wires yellow-lightblue, FAN- withe-green, FAN+ blue-red.
Where two motors are connected in serie A1-A2 there is a gray wire. Regards RR
  • Posted 15 Sep 2010 18:43
  • By roberto_r
  • joined 8 Sep'10 - 2 messages
  • VR, Italy
Hi Alberto,
Check your email it should help.
Shane
  • Posted 15 Sep 2010 18:36
hello friends
engines are two "marellimotori" Tip.k21 086 cl 24v, 20.8A, 1600RPM, 4000rpm-Max..
Thank you very much
AndyPandY, it's fantastic what you say but I am going to bits.
  • Posted 15 Sep 2010 10:26
  • By AMartins
hello friends my email is the following
alberto.martins54(at)gmail.com
  • Posted 15 Sep 2010 09:45
  • Modified 15 Sep 2010 09:51 by poster
  • By AMartins
Hi AMartins,
If you post your email address or send me an email I will send you some info that should help.
Regards Shane
  • Posted 14 Sep 2010 18:22
It sounds like you have a twin drive motor machine with SepEx motors (but this is only a guess). The light wires will be for the field current and the heavy ones for the armature. So long as the cables are paired correctly the only thing that should happen if you get them wrong is that they will drive the wrong direction.
But i am assuming a few things as your English is difficult to fully understand (my Portuguese does not exist).
  • Posted 14 Sep 2010 16:48
  • By AndyPandy
