Mitsubishi diesel forklift
Mitsubishi diesel forklift, 2500Kg model, proporcional valve, with fingertips for lift control, havent model and serial number.
In the control instruments have a light of safety continuous flashing. The machine everything works well. anyone know anything for this truck.
Regards
  • Posted 11 Sep 2010 02:32
  • By jesus_j
  • joined 24 Apr'10 - 9 messages
  • castellon, Spain
hello, the problem was in the setting logic card , was setting for a four valves spools, and the forlift has only a three valves spool.
I'ved changed the setting of the logic card and everything back to normal.
Thank you very much Andy
  • Posted 16 Sep 2010 02:16
  • By jesus_j
  • castellon, Spain
thanks Andy. I am very grateful.
  • Posted 15 Sep 2010 02:18
  • By jesus_j
  • castellon, Spain
jesuslift@gmail.com
Jesus, i have sent you the codes, hope they help.
  • Posted 14 Sep 2010 16:41
  • By AndyPandy
the seat switch is ok and the emergency button is ok. The forklift truck works well
Thanks
  • Posted 14 Sep 2010 04:59
  • By jesus_j
  • castellon, Spain
The first thanks for answering.
The logic card have a red led. This led one flash continuously. One flash, one second, one flash, one second.
Is a error code?
Thanks
  • Posted 14 Sep 2010 04:55
  • By jesus_j
  • castellon, Spain
Check seat switch and emergency stop button, these are the most common faults.
  • Posted 11 Sep 2010 21:58
  • By danny_k
This is part of the fault warning system. If you look under the rubber grommet on the hydraulic control card (behind the battery) you will see some LED's flashing which will give you the complete problem.
  • Posted 11 Sep 2010 05:06
  • By AndyPandy
Big Joe PDR30-154
USD7,500
SMV (Konecranes) 4531CC5
