Yale/Hyster Display problems
HI there
Anyone had this problem on the Yale/Hyster electric trucks where sometimes the dash display just dies on you?? Have had several over the years on different trucks with the same problem, suddenly the display stops working, sometimes if you disconnect the connector discharge battery and replug connector back in some of the lights appear but does not always work correctly.
Is this a known problem that has a fix?
The display is the one with the 1 to 5 numbers and allows u to select modes 1 to 4 through the display.
  • Posted 9 Sep 2010 07:40
  • Modified 9 Sep 2010 07:41 by poster
  • By elektrodrive
The only time I have had displays fail or develop funny symptoms on these trucks are in instances where the truck is fitted with white or polyurethane tires and no static strap is fitted. Especially in a polyurethane coated floor static electricity builds up to an enormous degree and causes all kinds of damage to sensitive electronic components, I had an hourmeter run backwards on me once. Check to see that the truck has either black tires or a static strap or chain or cable fitted and that it is clean.
  • Posted 21 Sep 2010 14:23
  • By steponmebbbboom
Hi Cert
Most have been off the XM series and all electrics.
Regards
  • Posted 19 Sep 2010 22:27
  • By elektrodrive
Yes I have, but I need to know if it's a XL2, XL3, XM, or FT/VX style, weither it's standard or premium, and weither it's IC or electric as the procedures vary. For some of the displays you need a special cable and program.
  • Posted 18 Sep 2010 10:52
  • By certifiedtech
  • joined 5 Aug'10 - 39 messages
Hi Tech
These displays are off previous trucks also and the trucks vary but they use the same displays on both hyster/Yale.
I think I have had some information through from a yale service bulletin about having to re-programme the displays?? Does this sound familiar to you?
  • Posted 16 Sep 2010 01:14
  • By elektrodrive
Hi Elektro,
Can you please list model and serial for truck as I believe I can help but I want to make sure I give you the right info.
  • Posted 15 Sep 2010 09:13
  • By certifiedtech
TCM FD115-3
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
